New P Sport Hydro 2015!
  • Shooter
    Team Mojo
    • Jun 2009
    • 2752
    #196
    Finally finished the brackets. Way too much time into these. The CNC at work made it a lot easier to cut out the center though. I won't be playing 'etch-a-sketch' ever again. CNC or nothing.
    • Shooter
      Team Mojo
      • Jun 2009
      • 2752
      #197
      ...and yes....I ditched the break-away feature on the latest version.
      • flraptor07
        • Aug 2013
        • 2451
        #198
        I want one! NOW!
        • darryl whitman
          • 581
          #199
          she's a real nice boat to build flraptor07 , 1515 2200kv with a twin 4s pack an a t180 esc , oh ya , fassssst
          • longballlumber
            • 3417
            #200
            Why? You would rather destroy the transom of your boat!?!?!
            • Shooter
              Team Mojo
              • Jun 2009
              • 2752
              #201
              This is probably the better option, from insane racing. Absolutely beautiful, but it's $100!
              • Shooter
                Team Mojo
                • Jun 2009
                • 2752
                #202
                Yeah!! Livin' dangerously! I'm not at all saying they don't work, but I've just never seen it. Every time I've ran over someone or something (tends to happen a lot on Wed night!), it just bends up the rudder and kicks the rear end of the boat up. I'd rather just have everything tight. That little brass screw doesn't put a lot of clamp on the bottom and from what I've seen, most people's rudders just end up on an angle after a few runs. I was reading somewhere that you can affect the handling of the boat in a turn with how you have the rudder angled (tucked under pulls the rear down, swung out lifts the rear in a turn). Who knows! It sure was easier to machine!
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2752
                  #203
                  So, for those that have seen Mike's stuffing tube installations, you know that they are a work of art. After talking with him a few weeks ago, I tried to give it a shot. I have (6) layers of very thin (3/4oz) glass on the tube with west systems. So far, so good.
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2752
                    #204
                    BTW, I don't know how the pros do it, but I've had pretty good success setting up boats this way:
                    Prior to gluing in the stuffing tube, I make sure the bend is set-up for 'neutral' strut position. I have two thin pcs of ply under the sponson bottoms to make up for the difference between the bottom of the strut and the centerline of the propshaft. Then, I adjust the strut until the boat bottom is flat to the table, calling this the 'neutral' position.
                    I loosen the collet on the motor shaft and spin the flex. If it's not absolutely free spinning on the motor shaft, I re-bend. Iterative process between bending and checking until it spins free.
                    I used to think that a nice solid shaft in the collet slipped into the stuff tube would center it, but there can still be side load. Anyways, this method has worked better for me, for what it's worth!
                    • longballlumber
                      • 3417
                      #205
                      Easy... Size the brass screw appropriately. Agreed the balancing act can be tough on proper brass screw size and shear strength. However, you can try and increase the friction between the matting surfaces pretty easy.
                      I disagree with your statement... You can just as easily break a rudder; ask me how I know.....
                      Later,
                      Ball
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #206
                        That's almost the setup I'm gonna use except with a SF 200amp Pro Plus.
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2752
                          #207
                          Last year I ran a 1515 2200kv with 8000mah, a Castle 240, and an H5 prop. Ran great!
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2752
                            #208
                            Good idea. I hadn't thought of that. Roughening up the contact surfaces would help. Now I suppose we are going to start discussing static and kinetic friction??
                            • darryl whitman
                              • 581
                              #209
                              I posted some ideas on that . Im tryin some sand mixin clear coat an place it on the last 3" of the sponsons, don't know if it will work ,
                              • darryl whitman
                                • 581
                                #210
                                oh ya , on the t180 esc, hard time with space , Shooter how big is the castle esc , might have to rethink this,
