Finally finished the brackets. Way too much time into these. The CNC at work made it a lot easier to cut out the center though. I won't be playing 'etch-a-sketch' ever again. CNC or nothing.
New P Sport Hydro 2015!
she's a real nice boat to build flraptor07 , 1515 2200kv with a twin 4s pack an a t180 esc , oh ya , fassssst
This is probably the better option, from insane racing. Absolutely beautiful, but it's $100!
Yeah!! Livin' dangerously! I'm not at all saying they don't work, but I've just never seen it. Every time I've ran over someone or something (tends to happen a lot on Wed night!), it just bends up the rudder and kicks the rear end of the boat up. I'd rather just have everything tight. That little brass screw doesn't put a lot of clamp on the bottom and from what I've seen, most people's rudders just end up on an angle after a few runs. I was reading somewhere that you can affect the handling of the boat in a turn with how you have the rudder angled (tucked under pulls the rear down, swung out lifts the rear in a turn). Who knows! It sure was easier to machine!Originally posted by longballlumber View PostWhy? You would rather destroy the transom of your boat!?!?!
So, for those that have seen Mike's stuffing tube installations, you know that they are a work of art. After talking with him a few weeks ago, I tried to give it a shot. I have (6) layers of very thin (3/4oz) glass on the tube with west systems. So far, so good.Attached Files
BTW, I don't know how the pros do it, but I've had pretty good success setting up boats this way:
Prior to gluing in the stuffing tube, I make sure the bend is set-up for 'neutral' strut position. I have two thin pcs of ply under the sponson bottoms to make up for the difference between the bottom of the strut and the centerline of the propshaft. Then, I adjust the strut until the boat bottom is flat to the table, calling this the 'neutral' position.
I loosen the collet on the motor shaft and spin the flex. If it's not absolutely free spinning on the motor shaft, I re-bend. Iterative process between bending and checking until it spins free.
I used to think that a nice solid shaft in the collet slipped into the stuff tube would center it, but there can still be side load. Anyways, this method has worked better for me, for what it's worth!Attached Files
Easy... Size the brass screw appropriately. Agreed the balancing act can be tough on proper brass screw size and shear strength. However, you can try and increase the friction between the matting surfaces pretty easy.Originally posted by Shooter View PostThat little brass screw doesn't put a lot of clamp on the bottom and from what I've seen, most people's rudders just end up on an angle after a few runs. I was reading somewhere that you can affect the handling of the boat in a turn with how you have the rudder angled (tucked under pulls the rear down, swung out lifts the rear in a turn). Who knows! It sure was easier to machine!
I disagree with your statement... You can just as easily break a rudder; ask me how I know.....
Later,
Ball
Good idea. I hadn't thought of that. Roughening up the contact surfaces would help. Now I suppose we are going to start discussing static and kinetic friction??Originally posted by longballlumber View PostHowever, you can try and increase the friction between the matting surfaces pretty easy.
I posted some ideas on that . Im tryin some sand mixin clear coat an place it on the last 3" of the sponsons, don't know if it will work ,
oh ya , on the t180 esc, hard time with space , Shooter how big is the castle esc , might have to rethink this,
