New P Sport Hydro 2015!
  • longballlumber
    • 3119
    #136
    Originally posted by darryl whitman View Post
    Longball would u plz take a photo so I can see what your talkin about, stinger ? thank u.
    Shooter I got 1 coat resin w/ 1/2 oz, glass inside an on the bottom outside . then 2nd coat over alllite sand then primer..
    started on the stuffin tube block, I'll post a pics soon
    There is a small gap at the forward sponson bulkhead and sponson stringer intersection that isn't at the rear sponson bulkhead. I agreed to build one of these for/with Pete and offer any feedback regarding construction. My preferred building methods are a little different than most; making my builds a little on the slow side.
    Later,
    Mike
    • darryl whitman
      • 535
      #137
      I had alittile of that too, but as long as the jig in front is square with the hull and both sponsons you will be good.
      • Shooter
        Team Mojo
        • Jun 2009
        • 2520
        #138
        OK, you guys got me. There was a constraint error after I added dihedral to the bulkhead and frames. See comparison of the model and Mike's build. This doesn't affect the build in anyway other than the slots have a tad more gap up front.
        I corrected the issues and re-constrained the model. I will also be introducing V5.5 shortly, with even larger bleeds!
        • T.S.Davis
          • 6228
          #139
          .........that is all.
          Noisy person
          • longballlumber
            • 3119
            #140
            No worries Pete,
            Not an attempt to bust your coconuts... This is what I agreed to do was give you feedback.
            You may want to review the rules in each organization regarding sport hydro planes before getting too radical on the vents and other "out side of the box" changes. It would be a shame if you spent all of this time and have an issue with rules making the boat ineligible for records or "sanctioned" event.
            I would just double check your in the clear.
            • Shooter
              Team Mojo
              • Jun 2009
              • 2520
              #141
              Sanctiined records are nice, but I'm just trying to beat Terry......and Ty!!!!!
              • darryl whitman
                • 535
                #142
                You go Shooter .LOL I think this boat is right up there,
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2520
                  #143
                  In all seriousness, the boat is NAMBA legal. I have to look into IMPBA.
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2520
                    #144
                    Well, after sanding again, it was evident that the second coat of resin just 'sat on top' of the first. Totally unnecessary and exactly as Mike said above. I sanded the second coat completely off. This boat is ready for primer.
                    And....here we go again! Version 5.5! Made a lot of minor tweaks again including extra notches for 1/8th spruce, deeper air bleeds, cross braced temporary motor mount, and notches in the transom for better alignment of the tub pcs. This build is going fast.
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2520
                      #145
                      Oh, and the slot issue is takin' care of....
                      • Shooter
                        Team Mojo
                        • Jun 2009
                        • 2520
                        #146
                        Darryl, I forgot to mention before, it is quite a feat to deck this boat without pre-fab pcs. Matching the curve was not easy on the first boat I built (prior to the pre-fab sheeting). I'm impressed. If you don't mind, please share your methods. Thanks!
                        • darryl whitman
                          • 535
                          #147
                          Shooter , you are so right about the top skin, what I did is I take a sheet of poster paper an lay the boat upside down
                          on it an trace around the boat, then cut out the shape , set the boat right side up, lay the cut out on top of the boat,
                          and place a few pcs of tape to hold it down , then with my finger rub the all edges of the frame , this shows me the
                          creases of the frame work, this is OLD SCHOOL pattern making but it works for me, also when you do this plz over cut
                          the plywood then sand down to fit. this can be timely.
                          remember to take 3/16 more off the inside edges of the top skin where the stringer runs , so your cowl and or lids
                          will sit on to be tape down. I'll try to get some pics of this to help .
                          Also Shooter , did you cut out notches on the 2 inner frames that run from the nose to transom so you can run 1 pc 1/8
                          stringers, sorry if you did on v5.5 , I didnt see it , thanks Shooter for a nice design. Darryl
                          Shooter ,
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2520
                            #148
                            Thanks Darryl. That's essentially how I did the first one.....applied pressure and creased the paper. Yes, very time consuming.
                            Not sure if I understand what location you are talking about regarding the notches. I certainly added more, but it was mostly in the cross stringers, not the axial stringers.
                            • darryl whitman
                              • 535
                              #149
                              sorry about that , yes the cross stringers is what I ment, that runs throw the sponsons. The guys here like the frame work. and they r giving ideas on the cowl. hoping to get hardware in next weekend,
                              • Shooter
                                Team Mojo
                                • Jun 2009
                                • 2520
                                #150
                                Yes sir. I've added several additional slots to make the build go quicker....
