OK, I FINALLY Ran my Cheetah yesterday at our PSFEMBC Club Race during practice time.
Didn't get any video. Evidence of the first runs never need to be retained, just in case!
The "factory" props that came with the boat are too small, so the speed wasn't impressive at all. Lots of RPMs... Lots of prop noise... not much "push"...
At the speeds I was going, the handling was "interesting"... As some have suggested, the hull was running pretty wet. When you turn into a corner, it somewhat drives the nose down.
HOWEVER, with the water a tad choppy, I could see glimpses of the boat freeing up quite a bit.
My preference for running a Cat would be for it to run more like an OPC Tunnel in regards to how it turns... Set the nose down and CARVE through the turn... NOT fly the nose and skid.
I think that, if I get the right props on this hull and get it up to the speeds I think it needs to be, the setup will actually work quite well and it'll handle great.
SO, I'm going to do some research and see if I can get myself a pair of correct props to try.
I think I may have a set of 45mm Graupner Carbon/Plastic props that I've been keeping around for doing a twin that may work for testing.
Next time out, I'll try to get some video.
