Redemptions redemption.
  • ls1fst98
    • 905
    I believe so. If someone knows more about it feel free to correct me. But I believe he did get a record, then either tried to break it again or was testing for the next saw event when the blow over happened.
    • ls1fst98
      • 905
      Just looked it up...it went 126.69mph
      • Espresso
        • Jul 2011
        • 248
        What size hull is this? HPR 135? That's incredibly fast for a large cat.
        • ls1fst98
          • 905
          Yes it's a 135 bulletproof layup. I'm not sure what he had for power...assuming lehners
          • Espresso
            • Jul 2011
            • 248
            Really good shape after taking a 100+mph blow over. Looking forward to how the 2028 powers it.
            • ls1fst98
              • 905
              I don't think the spill was 100+ maybe in the 80 mph range. Landed square on the left side of the hull.
              • keithbradley
                • 3671
                Nice to see you're going to have her back out on the water soon!
                I think you'll get bored fairly quickly with that cat on 8 or 10s though...I would run 12s on those motors and fairly aggressive props. These cats are at their best at higher speeds.
                To clear up a couple things...
                I didn't set any SAW records with this boat, I never even ran it at a SAW event. Due to the strict enforcement of the "max 25lbs out of the water" rule in the IMPBA, it never would have been legal to run (it weighed in at ~28lbs). I did run 120s multiple times and won the LOTO shootout "Top Gun" trophy with this boat, but no SAW records. It was crashed and broken when I finally decided to lower the voltage and prop down for some "fun runs". A 95mph crash is what did her in. While I have had boats crash at 120+ with no hull damage, this crash was an anomaly. There was no air time to speak of, no skips across the water, just one hard splat. The incredible force was apparent in the boat in many ways. For instance, on the bottom of the hull you can see where the 1/4" thick (I'm guessing on thickness...I don't really remember) motor mounts started to push through the hull. If you know just how thick/strong these bulletproof hulls are, you know that it took an extreme amount of energy to do that.
                www.keithbradleyboats.com
                • ls1fst98
                  • 905
                  Thanks keith, I knew someone would eventually chime in. Scott did a great job fixing her back up. I wasn't sure you could run 2028 on 12s. But I'll give it a go. Future plans are for lehners and mgm controllers.
                  • keithbradley
                    • 3671
                    They're only rated for 10s, but they really aren't made any different than the 56mm Chinese motors out there that are rated for 50k RPM. Caveat Emptor in this case, but since you're planning on Lehners in the future anyway, you might as well see what you can get out of those 2028s!
                    • ls1fst98
                      • 905
                      Got shafts in, props on. They are cnc 5218s.
                      Got my Parallel connector made for one esc. Takes the two sets of input wires down to 1.
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        Hi I have ran the 5216/3 CNC props on my previous MHZ138 and have to admit they didn't do much for the boat. But the MHZ and HPR like the 2 blade props a lot better. Something like a 57 cut down or straight up 57 S/B should give you good results also. Why the double wires into the double connector? Wouldn't you rather solder the 2 wired into one connector?
                        • ls1fst98
                          • 905
                          Thanks for the prop info. I'll be looking for new ones. This is all I have in this size range at the moment to get her in the water n see how she does. The connector I did this way in case I ever wanted to run 2p setup I unplug the short parallel adapter.
                          • ls1fst98
                            • 905
                            well here she is...i finally got her out on the water. this is on 9s on 5218s
                            • dasboata
                              • Dec 2010
                              • 3972
                              nice looking boat put some casted props on there if I can help you out LMK
                              • ls1fst98
                                • 905
                                Thanks. She's running cnc 5218. What would you suggest, was thinking 457
