Aeromarine Team Believer with updated hatch build. Special
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    #226
    this thing is nuts!
    but what about
    --Albert Einstein
    lol
    • rearwheelin
      • 1941
      #227
      Originally posted by Luck as a Constant View Post
      this thing is nuts!
      but what about
      --Albert Einstein
      lol
      I'm getting there ! lol
      --Albert Einstein
      • rearwheelin
        • 1941
        #228
        Zero paint , only KTM Hard Parts stickers and some orange reflective wheel stripe from CycleGear image.jpg
        --Albert Einstein
          Ok so when's the maiden? Are you gonna let me beat you to it? I'm putting mine together tight now and maiden is planned for tomorrow. Chop chop!
          • rearwheelin
            • 1941
            #230
            I'm having to much fun making everyone wait ! lol
            --Albert Einstein
            • rearwheelin
              • 1941
              #231
              Transom shot pic
              --Albert Einstein
              • rearwheelin
                • 1941
                #232
                And we have a dog for life
                --Albert Einstein
                • rearwheelin
                  • 1941
                  #233
                  Will grind the excess later.
                  --Albert Einstein
                  • rearwheelin
                    • 1941
                    #234
                    Sealed up the lights and added some more strength to the stuffing tube.
                    Nite nite
                    --Albert Einstein
                      • 5660
                      #235
                      I love every step of your build, can't wait to see a video. But if you want us to wait more, that's OK, I will be around, it's worth the wait.
                      P.S., staying up late, I see......
                      • rearwheelin
                        • 1941
                        #236
                        Thank Man ! Yep up late time for bed lol
                        --Albert Einstein
                        • rearwheelin
                          • 1941
                          #237
                          So much for getting the flex shaft built. I ran into a problem, the threads on a 1/4" to 3/16" step down OSE shaft are different unless this bullet nut that's been floating around in my parts box is metric or something lol
                          --Albert Einstein
                          • rearwheelin
                            • 1941
                            #238
                            Ok so I figured out there some sort ok coating on the threads of the shaft . Some Bel-Ray grease and a vise was the only solution since I had no die. Worked out good.image.jpg
                            --Albert Einstein
                            • rearwheelin
                              • 1941
                              #239
                              It flings oil so I will need to run small absorbent pads. I did a quick float test last night with no flex shaft to see if the RTR weight would make the water level higher than the stuffing tube and it was so water came in. Flex is built now and going to see how bad it is with the next float test . It may end up I that I need to minimize float times or get lighter batts.
                              Bench test vid: http://youtu.be/gLZF-gOzfl0
                              --Albert Einstein
                                I'm
                                Or you can machine the strut and put 6 sealed roller bearing in it like I've been doing. The stub shaft part of the flex fits tight enough in the bearings that there isn't any slack and water doesn't come in
