Aeromarine Team Believer with updated hatch build. Special
  • rearwheelin
    • 2101
    #76
    My pump cost me $20 from swap shop . My local dealer sells them for $28 and they have several others to chose from for less $. it works perfect with the check valves when I did my test.
    --Albert Einstein
    • rearwheelin
      • 2101
      #77
      I made this plumbing block for my inlets. It has the pump pick up built in. I still need to add the finishing touches but this is the design I'm going with.
      --Albert Einstein
      • rearwheelin
        • 2101
        #78
        Installed the thermal sencer . Dremeled down to the special copper compound core for the best heat reading I can get. Notched the 4 corners of the esc's plastic lower to hold the zip tie in place wich holds the switch in place. I will ad some thermal grease between the switch and core later on.
        --Albert Einstein
        • rearwheelin
          • 2101
          #79
          The lights are going here. They are blue.
          --Albert Einstein
          • Spartanator
            • 1060
            #80
            I was the one who sold you the pump... Lol
            http://forums.offshoreelectrics.com/showthread.php?t=47637
            • rearwheelin
              • 2101
              #81
              http://forums.offshoreelectrics.com/...ad.php?t=47637
              I thought so but figured oh well ha ha
              --Albert Einstein
              • rearwheelin
                • 2101
                #82
                Rubber mounted the lights with nylon washers. Bought a couple 3/16" rivets for the water outlets. Turned on the lights and they are pretty intense ! Very confident I will see them during the day !
                --Albert Einstein
                  #83
                  Some real cool ideas in this build, I am anxious to see how it all turns out!
                  • rearwheelin
                    • 2101
                    #84
                    Thanks J
                    --Albert Einstein
                    • rearwheelin
                      • 2101
                      #85
                      I felt it was time to make things permanent . JB welded the unit in and two water outlets.
                      --Albert Einstein
                      • dasboata
                        • Dec 2010
                        • 3972
                        #86
                        I like the lights , what are the blue cylinders for ?
                        • rearwheelin
                          • 2101
                          #87
                          They are 2.5 lb weights . There are pool noodles on the bottom between the sponsons under the motor area , the added weight made the JB push out the edges more uniformly .
                          --Albert Einstein
                            I thought they are some kind of compressed air cylinders for cooling in addition to your pump. . Your build is full of innovative ideas! Looking good!
                            • rearwheelin
                              • 2101
                              #89
                              Ha ha !
                              --Albert Einstein
                              • madmikepags
                                • Aug 2012
                                • 1371
                                #90
                                Why not just bolt the whole unit in from the bottom? that way it would have been removable for maintainance?
                                We call ourselves the "Q"
