Jim's PT Stealth 30
  • JimClark
    • 5913
    Jim's PT Stealth 30
    Stand is made
    Billy Graham
  • JimClark
    • 5913
    Billy Graham
    • electric
      • 1973
      Nice looking boat.
        Gorgeous!!
        Jim, your shop is up and running? Should I send you the VS1?!
        • capnswanny
          • Feb 2012
          • 867
          SEXY!
          This is NOT a toy?!?
          • JimClark
            • 5913
            I hate rattle can painting. sprayed the bottom first a couple of hours ago then turned it over to do the inside and sides. started sparying on some clear and that dried enough to handle I turned it back over to clear the bottom and wouldn't you know it it immediately started to lift the paint. Did I mention I hate rattle cans.
            Billy Graham
            • flraptor07
              • Aug 2013
              • 2451
              With Rattle cans you have to make sure the color you're spraying is the same type of paint as the clear you're going to use or it will lift most every time.
                Whoa! That thing is hot!
                • JimClark
                  • 5913
                  It was the exact same. i think I waited too long as the recoat is before one hour or after 48 hours
                  Billy Graham
                  • RayR
                    @SiestaKey.calm
                    • 1591
                    What?! No Bardahl graphics?!
                    • electric
                      • 1973
                      Been there, done that. Using the same brand of paint no less. I finally made the leap and bought automotive paints and clears and things jumped to a new level of durability and finish. A lot of work though.
                        Looks good Jim. I have also ran into the paint/clear issue. Thought about switching to auto paint but the prep/cleanup and $ for paint is holding me back. I have been using U-pol clear with good results mind you, as long as you let the base cure real well.
                        • flraptor07
                          • Aug 2013
                          • 2451
                          U-Pol is a awsome rattle can clear, my local Autobody supply has it. and they can put any color automotive paint into a rattle can. You guys might want to check with your local Autobody supply stores most of them can do that... It's deffinetly much cheaper than buying a paint gun and all the stuff that goes along with that. You get the same quality and result as long as you get good quality tips for the rattle cans, you can buy those sepperate too... http://www.ebay.com/itm/30-PROCAP-6-...item258fa56aa4
