P spec , prop for ML 310 hydro???
  • darryl whitman
    • 581
    Hi guys, got my ML 310 hydro glued up ,glassed , nice kit Mike, So now I'm planning
    to run P spec, setup . 2x2s 5000mah gen ace batts, motor is a 2030 kv , an the 60 amp
    aquacraft esc , can any of you pro boater give me some ideas on props, plz .
  • darryl whitman
    • 581
    here's some pics of my build.S7300963.jpgS7300965.jpgS7300967.jpgS7300966.jpgS7300964.jpg
    • ron1950
      • 3082
      good starting prop is a m445.....can work it up or down from there
      • electric
        • 1973
        Agree, great prop to start with(m445) and check the temps. If everything is ok, you can try to step up to the m447, but watch the heat. I am using a worked over m447 by Mark Shouland(sp?) for my Insane FE in P-spec. Nice job on the boat!
          Don't know how you guys turn a 45mm prop on a UL-1 motor. When I try I get 3 regulation laps before it detonates.
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            Ray,
            Same down here with later 2030 motors, particularly in the P-Ltd Cat class. We're mostly all propping down.
            • darryl whitman
              • 581
              ok? so maybe a , 442 or a 440? really don't wanna mess up things, at least my 1st sport 20 hydro.thanks for the warning.
              • Doug Smock
                • 5359
                A 442, 4255 etc, is a safe place to start.
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • darryl whitman
                  • 581
                  thanks Doug, I'll start with the 442,
                  • weil0127
                    • Dec 2009
                    • 200
                    I have the same boat and I run a M445 with good temps. If you want to prop down go to a x442 or cut down 445. I would also go to JRS Innovations for his motor mount, servo relocation and receiver mount. I have a build post of mine if you search under my name. Let me know if you need anything else.
                    www.namba20.com
                    • weil0127
                      • Dec 2009
                      • 200
                      Here you go
                      http://forums.offshoreelectrics.com/...-20&highlight=
                      www.namba20.com
                      • cybercrxt
                        • 2926
                        Very nicely built boat Darryl. I like the x445, but like some others have said, I am hearing little bits of the UL-1 motor not being as robust as it use to be. I wonder if the 1800kv version has more wattage ability?
                        Mike
                        • darryl whitman
                          • 581
                          Mike
                          thanks Mike, I do have an 1800kv, so maybe start with an x445 an work , up to a longer prop? Im still a noob .LOL also in Pspec class can I use any motor
                          that is rated the 2030kv an or 1800kv , an still be legal .?
                            Depends on your local club but, according to NAMBA for a sanctioned race you would need to stick to their rules. One of our local clubs doesn't care as long as it's no larger than 36mm x56mm and under 2100kv.
                            • darryl whitman
                              • 581
                              thanks Ray, I've been running with the locals here , an they r a lot of help to me , I'll see what rules they follow. but for the most part we all have fun.
