Making some battery trays out of CF since I tore out the stock ones from my BJ26. FIgured I'd post in here how to make some blank plates at home.
1) SAFETY FIRST! Wear a respirator and latex gloves when applying resin. Not a dust mask, a respirator.
2) Here are the glass plates I use to sandwich eveything between. They are 10mm thick glass, 12x12 (if I remember correctly). They were pretty cheap from a glass and mirror place (about $20 for both)
3) First thing you wanna do is throw down a couple coats of car wax. This will help with the glass releasing when you are all done. If you skip this step, have fun prying the panes apart without them shattering. Mold release will obviously work as well. Buff the wax out when it's nice and cured.
4) This is the CF I use, just because I have a big roll of it. It's 12K 2x2 twill. This stuff is VERY thick and VERY strong. Put tape on both sides before you cut it to prevent it from freying the edge, and cut down the middle of the tape. I cut the piece in half again as I am making a smaller plate (about 6"x10").
bonewar
