Whiplash 40 Q Sport
  • longballlumber
    • 3417
    #91
    Originally posted by Shooter View Post
    No sir. I run (2) 5000mah batts though, so it's rather heavy. We had our first race on Sunday and I was very happy with how this boat ran. Very stable, glued to the water, and plowed through the chop nicely. Turned good as well.
    Pete hit a home run with this one... It's running well already.
    Ray - don't start adding weight to a boat until you know it needs it! It's easier to add than it is to take it out (IMO)
    Later,
    Ball
      Will do Mike. I'm only adding 68grams to the left to balance out what I used for turn fin backer etc...
      Thank you! I think I'm going to go for Dinogy 4000's x 2... I'm talking to my sponsor about it, lol... aka the GF!
        Looks like you glued the nose blocks in before you sheeted the top, is this right? I will do it after I think.
        Tomorrow I fill it with foam blocks and skin it. Right now it's upside down getting a fillet of epoxy & chopped glass in the sponsons. The fillet is upside down so that's why. I tried to fillet with chopped glass in all joints of the sponsons. No weight added except the same aluminum as what was used for turn fin mount well... maybe just a 1/2oz of lead in the left sponson but, there's lots of epoxy in there.
        A couple quick updates on this one...
        Sanding, sanding, and more sanding!
        I added flotation. Not really sure why I do this. It's a fraction of what is required to hold it up.
        Top deck glued on with the usual ridiculous-ness of weights, tape, and clamps.
        • Shooter
          Team Mojo
          • Jun 2009
          • 2752
          #94
          Yes, I put the nose pcs on first. I don't think the order matters. So, you gonna have this thing ready for June?? Seems like a long time a way, but it will go quick!
            Yeah, I know, don't remind me. I'll be there a day or two early to test it, lol...
            If I skin it tonight then I have to clear it and do the canopy. The rest isn't too bad. I'm not working right now so, I have time, MAS just takes 24 hours to dry though.
            I am notorious for late builds... Still have a N2 Sport ML 265 to build and maybe a 335, lol... They are a lot simpler to build than the Whip. Just the size alone, 36" is a PITA to build while sitting all the time. Give it a try. Booo Hoo... I'll get'r done, I have to I'm supposed to be the TP Power dude of Q-Sport, obligations man!
            • Shooter
              Team Mojo
              • Jun 2009
              • 2752
              #96
              Done! FINALLY!
              • jfrancisco892
                • Feb 2012
                • 593
                #97
                Pretty as always lol.
                • ron1950
                  • 3082
                  #98
                  hey shooter did you ever sell that 20 size whip hatch?
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2752
                    #99
                    Yes sir. Sorry.
                      Sweet. I'm almost there, the aesthetics will not come anywhere close to your skilled finishing work.
                      How deep is your strut and are you using the 1250Kv 1527 or?? curious as to what prop you are going to try first, I need all the help can get.
                      • Shooter
                        Team Mojo
                        • Jun 2009
                        • 2752
                        #101
                        I'm running a 1530 (1355KV). 455 prop. I ran it at the first two club races and am very happy so far. Center of prop shaft is dead nuts with bottom of sponsons.
                        • detox
                          • 2357
                          #102
                          Cool. How much does the boat weigh "ready to run" with lipos installed?
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2752
                            #103
                            She's pretty heavy. 10lb 14oz w/10,000mah.
