I understand,
The only reason I ask is because OSE shows similar items assembled the other way.
] - Look at the lack of clearance between the starboard tab and rudder bracket. It's sometimes necessary to invert the bracket for clearance (notice how the rudder bracket is relieved for the adjustment screw). By mocking up the transom hardware before drilling/mounting this can be anticipated and compensated for by elevating the rudder foot location 'tho this can get tricky when the top bolts don't find secure internal footing. As long as the tabs can be set neutral they rarely need to be raised up over the bottom plane - they mostly go down to perform do their intended duty.
that's what I was thinking.
