The "Bling Rocket" build
    I had mine on it's hatch once from a big jet boat wake that it jumped and rolled over,
    But it did not land that hard on it.
    And the hatch stayed on with just the two very small pieces of tape I used for testing that day.
    As for score.
    I will give you a 9.6 because I played the video 9 times in slow speed,
    And saw the nice two dives and back flip in to the transom stuffing x two.
    Was that running on one or two 4s packs and with the tabs still up ?
      Tabs still up Len. Yup 4s2p. I had it going fairly good with that 4514. Smooth and all. Did need a touch of tab. But definitely needs a bit with 447. That was a step up for sure.
        Hey Shawn,
        Any idea why it did not float and bob instead of sinking ?
        I know you had built that nice bulkhead and stringers,
        But I forgot what you used for flotation in the bow.
        How bad is the hull beat up after the 9.6 dive ?
          Hey Shawn,
          The rear corners broke off the hatch where the bolts are. The boat floated, but the styro in the lid broke loose and the hatch went down. I have a plan for it's retrieval.
          • Paul Cafe
            Pauly
            • Feb 2014
            • 1
            #305
            Boys im very good reading threw threads. Need help. About to get hk pursuit. Trying to find pics for set up for good balance and handaling. So confused with al this talk 2p and so on need pics. Have brain injury any help would be appreciated thanks
              Hi,
              In this case in post #302 above we are taking about two 4s cell packs in parallel,
              That still = 4s but it is two X what ever the Mah is of the pack.
              So that gives you more amps for the setup and a longer run time to.
              Now this link below has to do with how some cell packs are made and put together,
              As a 1p or 2p pack. http://forums.offshoreelectrics.com/...6-2s1p-os-2s2p
                And what else would you like help with Paul,CG(weight distribution)? Layout?
                Shawn
                  So I think we had the CG at around 9.5" from the transom, give or take.
                  So I finally plugged this thing in to power today. Works fine
                  So next step is to make a temp hatch till I can get the one off the bottom. I could just swim if it ever warms up. Just started snowing here again this morn.
                  • flraptor07
                    • Aug 2013
                    • 2451
                    #309
                    Get your wetsuit on and jump on in there, SISSY!!
                      SISSY??? Really???
                      LOL
                      • Rocstar
                        Joel Mertz
                        • 1536
                        #311
                        I have two hatches that need to be retrieved, bring a chainsaw....ice is thick.
                          Do you not put foam in your hatch? With your skillz I would think you could do something like I did that looks good and is functional.
                          • Rocstar
                            Joel Mertz
                            • 1536
                            #313
                            Skillz? Nah, I don't have any skillz....
                            • flraptor07
                              • Aug 2013
                              • 2451
                              #314
                              You guys are makin' me cold just lookin' at those pictures!!
                                Well I did have a chunk of foam in there but it was half done. Kept thinking I should put some cloth over it , but... Didn't happen and in the vid you can see the foam blow off.
