Good,
Than there should not be any viking funeral for your baoat.
All the temps on your setup you want to keep at tops 135f and the lower the better.
Now if you where running a outrunner motor that could run a lot hotter,
And still handle it for the most part at 210f tops on the motor only.
Everything else like I said above at 135f or lower.
Also do not forget to check the temps on all the connectors setup to,
They can get very hot to and be a weak link in the setup some times.
Originally posted by stelerzman
View Post
Thanks.
I looked them over and I don't think they'll work. I do have something else in mind that will be brazed to the larger size stuffing to and then attatch it the the flood tube. I may also make a bracket for the back of the transom to support it on both ends.
