See how the stumble pads stay bonded to the center section, but not the sponson at this time:
Now its time to bond the sponson top decks: This is the most critical part of the build besides the center section top deck. If you have a twist in the sponson after the top deck is on..the twist stays!
In preparation for the top deck bonding, you will again want to put down a riser on the flat board. This will allow you to clamp down your sponsons while the top deck sheeting drys, ensuring the sponsons do not get twist while you tape the decks on!
Epoxy the decks on, tape them to the sponsons, and put them on the riser, and gently clamp in areas that do not affect the top deck.
Once the sponson decks are dry, using your sur form, and sanding block and clean up all the outside edges:
