ML Boatworks, PX335 O/B Tunnel, 33.75" FE , frame up design like the PX/NX300 kits!
  • cybercrxt
    • 2926
    Well, another new tunnel in the stable. This hull is based off the excellent running PX 300 P-limited FE and NX300 Nitro, both 30" hulls. If some of you do not know, my whole tunnel boat lineup is now a frame up design, which means no more difficult wood over foam.
    This lineup will also include a 39.5" FE tunnel called the QX400 which I am building now, and there will also be a 32", 35" and 39.5" lineup for the nitro engines. If you have a flat board, and a sanding block, you can build these tunnels! Now, I have posted most of the build here, but you may want to see the intlwaters thread too. My test hull has an OS lower unit, Neu 1521 1.5d motor, Castle Ice esc, and (2) 4s, 45c 3300mah Hyperion packs for 6600mah total. The boat runs silky smooth in the straights, and through the turns. Its my favorite boat, yes boat) I have built to date. It handles the speed very very well! Went ahead and added all the info, but there may be more info on the Intlwaters thread, please visit this link:
    Well, I have had a lot of interest in the PX 300(FE) and NX 300 (Nitro) 30" o/b tunnel frame up kits. A lot of people have asked for guidance with the build, so last weekend I spent about 7-8 hours from start to finish, and put together a PX335 kit. I am actually wishing I had done these frame...
  • cybercrxt
    • 2926
    First, here is a few pics of most of the kits vital parts:
    Sponson framework:
    Sponson sheeting:
    Center section upper and lower pans, forward to aft members, radio box sides, and internal framing:
    • cybercrxt
      • 2926
      The first thing I will suggest, is a tool Phil Thomas told me about a few years ago, a Stanley Sur-form. If you don't have one of these $7 tools..GET ONE, it has changed my boat building life! It is by far the easiest way to avoid breaking through layers of plywood while trying to sand 90 degree surfaces flush.
      First thing you will want to do, is grab sponson crossmembers #1L (there will be a frame with holes, and one with out) and #1R (same as left side, one with holes, one without), and glue them together. This makes up the sponson transom plates:
      Now find your sponson Keelsons (the long inside edge of the sponsons), lay them on your flat board, clamp them down, then start dry fitting your sponson internal framing (All framing has numbers, and an R for right, and an L for left that match with number on the sponson keelson plates), and then put the sponson outside edge (sponson shear) in place like this:
      As you can see, that outside sponson shear will lot into the crossmembers, forcing the parts to be 90 degrees to the keelson..Its almost fool proof!
      Now glue the nosing, one above, and one below the sponson shear at the front of the sponson:
      • cybercrxt
        • 2926
        Now you can use your Stanley sur form for the first time, and flush in the lower edge of the outside sheeting like so:
        And finish sand with a sanding block and 180 grit to smooth it:
        Next, glue on your sponson non trip sheeting. The pictures below show it already sanded in flush, you will have overhang on each side...once glued, go ahead and use your stanley sur form and flush in each edge.
        Now, I suggest getting something to elevate your sponson from the building board, as you are going to want the inside ride pad edge to overhang so you can sand it properly after installed. I used (2) 3/16"x 3/16" basswood, layed them on my building board, then clamped the assembly down:
        • cybercrxt
          • 2926
          Now, find your ride pads, and dry fit them, and what you want to look for is excessive overhang on either side. On the outside edge, it is critical to sand improper overhang before gluing. This outside edge stay blunt, and if you install it without checking for a nice clean blunt edge that runs parrallel to the non trip surface, you may have some areas you cannot sand clean later. I just marked my ride pad where I felt it needed sanding down, and sanded it on a disc sander. :
          Your ride pad outside edge should resemble this after gluing. You will notice the inside edge has a lot of over hang, and the outside edge is very clean and tight against the non trip all the way forward:
          Once you have the ride pad glued, now remove the clamps, and sand the inside edge with the sur form like this:
          Now, Mark on your ride pad from the inside edge, outward, 1-3/8" in two locations. One at the sponson transom, and one around 10" forward. This will ensure your secondary ride pad is parallel to the primary pad that is already installed:
          You can see where I am pointing to the dot that is around 10" forward:
          • cybercrxt
            • 2926
            Once the primary pad is marked, you can now dry fit your secondary ride pad:
            Here you see the overlap of the secondary pad on the inside edge.. I suggest removing some of that...leave some overhang, but removing some with a saw now, will make your sur form sanding shorter once the secondary pad is glued in place:
            You can see I marked leaving make 1/8" overhang:
            Now you can see where I marked a line all the way forward so I had a guide while sawing:
            • cybercrxt
              • 2926
              Now that you are done with the dry fitting, reclamp your sponson to the flat board, with the elevated platform so you can glue your secondary pad:
              Add some CA, and line up the secondary pad with the dots you put on your primary ride pad earlier, and bond:
              Now sand away that overhang of the secondary pad:
              • cybercrxt
                • 2926
                And your finished ride surface should look like this. Repeat all the above sponson steps with your other sponson. We will glue the sponson top deck later.
                Its a good idea to store the sponson clamped together until you are ready to epoxy the interior...like this:
                OK, so lets move to the center section. Gather all the center section parts, and lay them out. The pics in the 2nd post should have familiarized you with the parts. We will start by dry fitting a few things:
                Once you are get a feeling for how the crossmembers fit, it is time to laminate a few parts. The transom plates A1, A2, A3, and A4 will be bonded together first:
                There are also two plates labeled "H" that make the forward nose of the center section...glue them together too:
                Then you will have a double layered radio box/ center frame. Bond like the following for each side:
                • cybercrxt
                  • 2926
                  Another shot of the center frames...note, only one side is bonded in this pic:
                  Now, dry fit the transom plates, frame B, frame G, and the radio box sides..once dry fit, insert the assembly into the floor pan toy tabs, only checking for fitment at this time:
                  At this time, tape the front area of the radio box, just to keep it secure, and it is now time to bond plate "H" to the floor pan like this:
                  While your dry fitted assembly is still loose, insert a 1/8" x 1/8" basswood stick in the location I am pointing too:
                  I now suggest clamping your pan down so that it is good and flat agains the flat board. Keeping the floor pan flat, without a twist will be key to your build. If the center is twisted, the sponsons will not lay flat on the board later on!
                  You can now start inserting the other crossmembers:
                  • cybercrxt
                    • 2926
                    It is now time to slowly glue all the crossmembers, and radio box plates down, being sure all is square. Once you have those bonded, you can start putting in the radio box lid parts. Having them installed will help minimize twisting of the assembly, making the rest of the center section build a little easier.
                    The lid and tab. If you haven't noticed by now, there were two tabs in the kit. One for the hatch, one to support the rear area where the hatch lays down on.
                    I also ran some 1/8" x 1/8" basswood sticks down each side of the radio box for extra strength:
                    and tape it shut for now, and add the upper piece of 1/8" x 1/8" basswood stick:
                    • cybercrxt
                      • 2926
                      Now add this piece of 1/8" x 1/8" basswood:
                      And add the outer side plates, and remaining 1/8" x 1/8" basswood stick. Please note, the kit offered will not have all the crossmembers protruding through the outside side plate...this was an error on my part!
                      • cybercrxt
                        • 2926
                        Now test fit your sponsons to center section toy tabing. It should lock right in!
                        On the final kit, I have gone back and added 1/8" x 1/8" slots in the center of the top of the crossmembers so a basswood stick can run forward to aft. I added this to my kit as it helps keep the sponson from twisting.
                        Now we are to the epoxy stage for the sponsons. My first suggestion, is to put masking tape on the inside sponson plate (keelson), this will help keep epoxy from leaking through and bonding your sponsons to your building board! You can also cut up some fiberglass cloth or carbon fiber and lay it in your ride surface area before epoxying.
                        I also suggest adding some floatation to the inside of the sponsons, and center section. Here is what I used:
                        Once you have coated the inside of your sponsons with epoxy, and pushed the foam floatation into place, I highly recommend clamping you sponson back on the flat board.
                        • cybercrxt
                          • 2926
                          Now that your sponsons are drying, its a good time to finish up the final sanding on the center section framing where the center top deck will bond...this means its time to use a sander to bevel the front nose so the deck will lay down:
                          Then, take some scrap 1/8" basswood stick, and cut it up, and add it to the crossmembers at the top. This will increase your bonding strength when epoxying the top deck down:
                          Now cut some foam for your center section floatation:
                          • cybercrxt
                            • 2926
                            Now, add some masking tape to the bottom, covering the toy tab slots..to remove the chance of epoxy bonding your center section to the building board!
                            Its also time to trim the foam around the dowel rods (you can either add, or dont add the dowel rods, they are your choice. 5/16" dowel or brass tubing is required). After you are happy with your dowel and foam, remove them, epoxy the inside, and replace..you will end up with this:
                            While the center section interior epoxy is still wet, its time to epoxy the bottom side of the top deck, and tape it down on the center section framework. I also like to use CA around where the top deck touches the radio box. Its hard to get tape to hold that area properly..a touch of CA in that area will ensure your deck stays in place while drying. Remember to clamp and weigh down your center section corners, and middle..remember, keep it from being twisted as once the top deck drys you cannot remove any twist!
                            • cybercrxt
                              • 2926
                              Now do a dry fit clamping of the sponsons and center section once the parts are dryed. Just look over the bond seam between the 3 parts and make sure its nice and clean, and take a 90 degree angle and check the tunnel to sponson fitment..should be good and square..if not, your center section top deck may be pushing the sponson out of place...check it over:
                              another view
                              While dryfitted, check and make sure your sponson inside edges are nice and flush to the building board. If not, look check for twist in your center section, or if your ride pad is not sanded properly.
                              Make sure its 90 degrees and square!
                              While clamped you should go ahead and bond the stumble pad to the bottom of the center section...DO NOT bond the stumble pad to the sponson yet..just have it pushed up against it. You will be gluing that surface when you permanantly bond the sponsons to the center section later.
                              The trailing edge of the stumble pad will need to be around 17.25" forward of the sponson transom. This applies only to the PX335..... The PX300 and NX300 is 16.2". The QX400 will be determined soon.
