Hpr 115 round 2
  • keithbradley
    • 3671
    Looking good Chris...and should run great!
    I'm always a little shy to run these in wye the way you do...in my experience the actual kv when ran in wye is not always what you would think it would be. On paper, this one should be a killer setup though.
    EDIT: I guess I should say that I'm shy to ORDER them that way...running them in wye is not a problem.
    www.keithbradleyboats.com
    • Chrisg81983
      • Jul 2011
      • 1585
      Hey keith how are you ??? I still cant figure out why u had such a difference between the two 2240/5 's. When I ran them both of my hydra ices and eagle tree confirmed that the two motors were never over 113 rpm apart. On a normal they were within 60 rpm's of one another. If possible can you send me the logging file and I will do the same as it will be interesting to compare.
      Mike I am not sure about the wait time for an hpr, but whatever it definitely worth the wait nomatter one week or three weeks. If you are serious about getting one I would talk to manuel about it. A pair of TP 4050 L 2350kv will get u to a 100 mph if set up correctly. You can also get by using the t180 as they perform very well with that setup. So 100 mph can be done with a relatively cheap setup.
      • Livewire121
        Fast Electric Adict!!
        • 320
        Lookin good Chris!!
        HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
        • keithbradley
          • 3671
          I wasn't referring to comparing two of the same motors Chris. What I meant was this: Lehner motors are rated loaded. There is a bit of a correction factor assumed for RPM drop under a given load. So, a 1600kv Lehner might actually turn 1650kv unloaded (just making up numbers). I believe that the difference between a loaded and unloaded motor's kv will be greater with the higher kv models. For example, a motor that turns 500kv unloaded might turn 480 loaded. A motor that turns 3000kv unloaded might run 2400kv (again, I'm just pulling numbers out of the air here to demonstrate a point).
          So... when comparing a D to Y wind, the factor of 1.73 can be used to determine kv. However, with a motor that is rated at a loaded RPM, the correction factor will be greater in D configuration than it will in Y configuration, meaning that the math may not be linear. Essentially what I am saying is that I don't have 100% faith when ordering a motor that the final kv in wye will be 1.73 of what is listed on the site. Your motors should be ~1710kv right? Have you found that they are consistent in this? I have only ran a few pair of Lehners in wye, but they have been a bit higher in kv than what I expected.
          • Jason4636
            • 712
            Hey Chris looking great, sorry I haven't seen this thread before. been busy moving.
            • Chrisg81983
              • Jul 2011
              • 1585
              Keith what's up I was a little unsure what you meant but got it now. I found they are damn close to what it should be. I think my 3040 are within 50 rpm of what it should be. I will look into it further and let u know.
              jason whats up how is your mono doing.
              • drwayne
                • 3012
                Another impressive build, Chris.
                Are you done yet ?
                • Chrisg81983
                  • Jul 2011
                  • 1585
                  Thank doc how are you ? Almost done I hope lol. I will probably be done by end of week
                  • iridebikes247
                    • 1669
                    Pics do the boat no justice. Recently had chris help rebuild a mystic 138 with me his build quality is second to none. Anyone wanting a 100mph boat that survives even the worst of crashes this who you go to lol.
                    • Chrisg81983
                      • Jul 2011
                      • 1585
                      hey thanks mike how are you feeling and by the way I can't wait until we run your 138
                      • Chrisg81983
                        • Jul 2011
                        • 1585
                        Ok guys been busy but I did manage to get the carbon work all done and motor mounts in. The 2250's came from lehner and are awesome as usual. I am posting pictures in a few min.
                        • Chrisg81983
                          • Jul 2011
                          • 1585
                          Here are some pics and I also forgot to mention I completed the water inlets and countersunk hatch bolts. More pics to come
                          • Chrisg81983
                            • Jul 2011
                            • 1585
                            More
                            • Chrisg81983
                              • Jul 2011
                              • 1585
                              Heres the inlets and hatch bolts
                              • Chrisg81983
                                • Jul 2011
                                • 1585
                                I also wrapped the stuffing tubes all in carbon while also getting them installed and only tacked in with ca glue need to go over with epoxy.
