The LOOSE GOOSE Custom Build
  • Neveryachtz
    • May 2013
    • 82
    #46
    --- We Cut Foam ---
    They are in San Jose. It was $400.
    It was worth it for the CNC. Only I would make them decrease their tolerances next time because it was pretty rough, some of the steps aren't as deep as they should be, strakes are not straight, etc. I fixed it all with the coating and sanding, but for $400 I shouldn't have had to put that much work into it myself.
    • Neveryachtz
      • May 2013
      • 82
      #47
      As a Bay Area native I'd be proud to represent the America's Cup.
      Here's a possible livery:
      • M3Roc
        • Dec 2012
        • 2
        #48
        Wow that boat looks great! Following!
        Im hoping to get my hands on a Spartan soon that I plan to modify a little by changing out some components but this project is awesome!
        • Neveryachtz
          • May 2013
          • 82
          #49
          The plugs are about done. They just need some wax.
          Still not sure if I should brush or spray PVA. I don't have a spray gun so I'd have to buy one. Is it worth it?
          • jcald2000
            • 786
            #50
            I wipe a wet coat on with a piece of clean T-shirt, has worked well for several plugs.
            • Neveryachtz
              • May 2013
              • 82
              #51
              I get confused because half the people I talk to say that works fine. And others swear by spraying. As soon as the paint cures I'll wax, then do a test run and see for myself.
              • Grazacind
                • Jan 2011
                • 351
                #52
                [ATTACH=CONFIG]105725[/ATTACH][ATTACH=CONFIG]105726[/ATTACH]
                It should be Oracle team AUS they got the letters mixed up.
                Andrew
                Find it + Buy it + Twin it + Run it = WOOHOO
                • Neveryachtz
                  • May 2013
                  • 82
                  #53
                  Hahaha yeah. But hey, Spithill married an American woman so we'll let it slide.
                  • Neveryachtz
                    • May 2013
                    • 82
                    #54
                    Man I haven't updated this thing in a long time.
                    Boat still isn't done unfortunately. Here's some progress that has been made on the build.
                    Deck and Hull molds
                    • Neveryachtz
                      • May 2013
                      • 82
                      #55
                      Did a vacuum infusion test on 2 different cloth layouts.
                      First is a 2x4x2 of carbon fiber and glass. 8 layers total.
                      Second is a 4x4x4 of carbon and glass. 12 layers total.
                      Carbon is 2/2 twill 3k 199g. The glass is 6oz E glass.
                      • Neveryachtz
                        • May 2013
                        • 82
                        #56
                        The weight for the 8 layer setup turned out to be .055 oz/in^2
                        The weight for the 12 layer setup turned out to be .081 oz/in^2
                        For the boat deck and hull I decided to go with a 3x4x3 layout. Should be about .068 oz/in^2
                        According to the SolidWorks model the boat has a surface area of 1050 in^2
                        So the final product should weigh about 4.5 - 5 lbs. The hardware and batteries weigh about 7.5 lbs
                        Finished boat should weigh about 12-13 lbs give or take.
                        • Neveryachtz
                          • May 2013
                          • 82
                          #57
                          This is where I am at as of now. Infusion of the deck is complete. The 3x4x3 layout added up to 2 lbs 10 oz. There is a lot of excess material that needs to be cut off so it actually weighs a lot less.
                          • Chrisg81983
                            • Jul 2011
                            • 1585
                            #58
                            Looks great bro can't wait to see it complete
                            Sent from my XT1080 using Tapatalk
                            • mekzoid
                              • Nov 2011
                              • 120
                              #59
                              Wow can't believe I missed this thread.
                              You are putting some great work into this mate. Cant wait to see it finished!
                              • Neveryachtz
                                • May 2013
                                • 82
                                #60
                                Learned some new rendering tricks.
