The LOOSE GOOSE Custom Build
  • Neveryachtz
    • May 2013
    • 82
    #76
    Here she is. I can't say how relieved I am to have this in my hands after all the research and sweat I have put into it.
    • Neveryachtz
      • May 2013
      • 82
      #77
      These pics show the filler mixed resin in the steps and strakes. The resin turns white when the filler is added, the black parts are the normal infused resin where there is no filler.
      • Neveryachtz
        • May 2013
        • 82
        #78
        A little teaser of the profile. I have a lot of trimming to do
        • Neveryachtz
          • May 2013
          • 82
          #79
          Here's the filler if anyone is interested. I used the 403.
          • Neveryachtz
            • May 2013
            • 82
            #80
            Originally posted by larryrose11 View Post
            Here is some new vacuum infusion tech for ya, MTI hose.
            It is a hoze you use on the vacuum site that prevents resin from entering the vacuum line, but also dost clog. So, when resin flows to it, it stops, and will continue to flow to other areas. You can actually calculate ho much resin to mix!!
            A composite professional friend told me about it, says it works super well.
            http://www.dd-compound.com/index.php/en/
            Looks interesting. But I don't run my spiral tubing all the way around my part, just at the inlets. So I'm not sure if I would benefit from it.
            • Neveryachtz
              • May 2013
              • 82
              #81
              Originally posted by Fella1340 View Post
              I have no doubt you'll be able to cut the hatch out nicely based on your previous work. Hopefully the area is flat to make your life easier. Any chance of seeing some more of your computer rendered version of the boat. It would be nice to see out of the water, the transom, bottom and front view. It's tough to see all the details done in carbon. Are you happy with your computer rendered versus the final result? I just want to see more! I look forward to seeing this updated, the more pictures and lots of detail would be much appreciated and I know others would enjoy that to. If your busy no worries, just wanted to ask.
              There are several CAD pics on the first page of this thread, along with some specs of the hull and parts. But I'd be glad to post more detailed pics if you have any requests.
              As far as reality vs computer, I don't think I am far enough along yet to tell. But I will definitely touch back on that question when this is all said and done.
              • Fella1340
                • May 2013
                • 1025
                #82
                Beautiful job, love the carbon! The boat design is up there with the best. I am biased towards mono hulls. You will make an excellent engineer, the ones with hands on experience are always the best and I have worked with to many to count over the years. I look forward to seeing this hull fitted out and hit the water. I can appreciate the time and energy put into it, impressive work. I couldn't tell your new to this stuff.
                • larryrose11
                  • Jun 2010
                  • 763
                  #83
                  Great work!!
                  • Chrisg81983
                    • Jul 2011
                    • 1556
                    #84
                    I use every one of the additives they work awesome.... hull looks great it resembles the new MHZ silverhook
                    Sent from my XT1080 using Tapatalk
                    • twissted
                      • 867
                      #85
                      Well if you need a part time job, just fall back on your Hobby!!!
                      twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
                      • Simon170
                        • 101
                        #86
                        I'm not sure if you realise this, but you've built Batman's weekend boat!
                        Looks awesome! I want!
                        Still in dry dock... But planning to get wet soon.
                        • Neveryachtz
                          • May 2013
                          • 82
                          #87
                          Thanks, that means a lot.
                          • Neveryachtz
                            • May 2013
                            • 82
                            #88
                            Cut the hull and deck down. Hopefully it will be one piece by the end of the weekend.
                            • Espresso
                              • Jul 2011
                              • 233
                              #89
                              Looks really nice all trimmed.
                              • Fella1340
                                • May 2013
                                • 1025
                                #90
                                That's one sexy boat. Time to start thinking about what's going inside. Ant ideas yet?
