BBY Micro Turbine Hydro for SSSH
  • Sneasle
    • 197
    #346
    good to know. I'll look and see what I can find.
    I assume there is a weight penalty with FG as well, I just wonder how significant.
    edit:
    what size packs are you running on this? 2s, 3s, capacity?
    • Dr. Jet
      • 1707
      #347
      I'm using 2S packs of 1300 to 1900 mah.
      • JimClark
        • 5902
        #348
        Hey Doc I got my motor esc combo but was wonderign about programming the ESC to get it to work with a wheel radio. Any tips on programming?
        Jim
        Billy Graham
        • Dr. Jet
          • 1707
          #349
          If you have the yellow ESC, no programming is necessasy. Plug 'n Play.
          • Sneasle
            • 197
            #350
            Can someone give me the dimension of Joe's rudder?
            Is a 7cm rudder too long for the hydro?
            • J Solinger
              • Apr 2008
              • 197
              #351
              I have put up the overall dimensions on my web site. Click on "Micro Hardware" then click on the photo.
              Joe Solinger
              • Sneasle
                • 197
                #352
                Cool, thanks Joe.
                can I order from you off the site or do I just need to pm you when I am ready?
                • J Solinger
                  • Apr 2008
                  • 197
                  #353
                  Just send a pm when your ready.
                  Joe Solinger
                  • RandyatBBY
                    • 3915
                    #354
                    Well the little MTH just Bumped the record 14MPH to 48 Miles per hour and some change. God job Wilmer! That is flying in a little 15 inch boat1
                    Randy
                    BBY Racing
                    • Sneasle
                      • 197
                      #355
                      say what?
                      dare I ask what was running in that boat to get this little hull to 48?
                      • RandyatBBY
                        • 3915
                        #356
                        A 19t stock motor and 8 Nimh cells.
                        Randy
                        BBY Racing
                        • Sneasle
                          • 197
                          #357
                          that doesn't sound all that hard to do.
                          Hmm... I wonder if this hull can break 60 easily....
                          • RandyatBBY
                            • 3915
                            #358
                            Hard? Will has been testing this hull for a year I have been giving him tips and he has some real creative ideas. It would be easyer with brushless ie big motor High KV, three cell and real smooth water.
                            Randy
                            BBY Racing
                            • Sneasle
                              • 197
                              #359
                              I just meant that the motor/batt combo didn't sound very challenging to put together. Nothing in '19t stock with 8cell nimh' sounds all that special.
                              If there is something special (ie, weird thrust angles or some strange cg stuff), then I would love to hear about it.
                              If there are some specific numbers that went into how that boat was built, please share them.
                              • Dr. Jet
                                • 1707
                                #360
                                Wilmer has a "modicum" of experience with these little car motors. I'm willing to bet he managed to "tweak" it just a little bit. Furthermore he has been known to make many different small boats perforem quite well. You can rest assured he probably didn't do 48 mph on the first, second, or even third outing. He works hard to get results few others can match.
                                As for doing 60 with this hull, it may be possible on 3S with something like a small NeuMotor.
                                As for my build, I think I may sacrifice speed for style on this one. I have joined the hull/deck and shaved the lip off. Currently, I am sharpening and truing all the surfaces on it. I'm using epoxy/ Cab-O-Sil for the building up of the edges, so it takes a day just to apply one layer; a day to sand it; another day for another layer; and so on. It will be a while before it is ready.
                                Like I said earlier, I have decided to try a different (but still under $25) outrunner/ESC combo to see if it has a bit more "zip." Photos will follow when I have something interesting to show.
