BBY Micro Turbine Hydro for SSSH
  • Sneasle
    • 202
    #361
    Excellent.
    Good to know. Tunning is an art, and I'm glad Wilmer got great results.
    Your shaving sounds similar to what I was considering doing.... get rid of the lip. I look forward to seeing your picts of progress and hearing how that motor/esc combo runs.
    Keep us updated.
    • JimClark
      • 5913
      #362
      A higher KV Doc?
      Billy Graham
      • Sneasle
        • 202
        #363
        Originally posted by JimClark View Post
        A higher KV Doc?
        I think he said it was 3500kv compared to 3000kv of the other motor.
        • Dr. Jet
          • 1759
          #364
          Actually, it is 3850 rpm/V, so we shall see what happens. I'm thinking it may be fun.
          I'll take more photos when it looks like something worthwhile. I've been lying a bit low since I received some rather vicious responses and a vulgar and vitriolic PM from an illiterate buffoon stemming from a (what I thought a seemingly harmless) post on another thread. Such is life.
          A nation of sheep breeds a government of wolves
          • Sneasle
            • 202
            #365
            that blows.
            Please keep us up to date. We will chase the monkey off if need be.
            • Dr. Jet
              • 1759
              #366
              Don't give it another thought. All that has passed.
              Photos will follow soon.
              • RandyatBBY
                • 3943
                #367
                I just meant that the motor/batt combo didn't sound very challenging to put together. Nothing in '19t stock with 8cell nimh' sounds all that special.
                If there is something special (ie, weird thrust angles or some strange cg stuff), then I would love to hear about it.
                If there are some specific numbers that went into how that boat was built, please share them.
                Not a problem, I was just trying to say that it takes time on the water. But that is what we want to do!
                Randy
                BBY Racing
                • Dr. Jet
                  • 1759
                  #368
                  I'm about 50% done with the filling and sharpening. Here are some progress photos.
                  • Sneasle
                    • 202
                    #369
                    That looks excellent.
                    You need to post some details about how your doing it at some point so the rest of us can take advantage of you having already gone through the process.
                    Are you sharpening all of the edges? It looks like you've been working on the bottom of the hull as well.
                    Remind me again, where did your silver pipe some from?
                    • tylerm
                      • 310
                      #370
                      Thats pretty fly Doc, good job
                      Keep it up,
                      Tyler.
                      • Dr. Jet
                        • 1759
                        #371
                        It was cheap drug store "scented spray" for chicks. You have to do some shopping in the cosmetics section.
                        • Sneasle
                          • 202
                          #372
                          Ah. I wonder if an Axe can will fit. I have a few of those floating around.
                          • J Solinger
                            • Apr 2008
                            • 197
                            #373
                            It has a great profile. Nice work Doc.
                            Joe Solinger
                            • J Solinger
                              • Apr 2008
                              • 197
                              #374
                              48 mph, that realy is cook'n in this boat. Wilmer's definately got the nack for pulling speed out of small hulls. My sincerest congratulations.
                              Joe Solinger
                              • Dr. Jet
                                • 1759
                                #375
                                How he manages to keep the thing on the water amazes me. Almost 50 with this hull is insane.
                                Details for the sharpening/blueprinting are simple. I mix epoxy and Cab-O-Sil into a thick paste consistency. About like cable grease. Then I use a credit card to spread it around. Several flat sanding blocks makes shaping it easy. Build it up, sand it off, fill the low spots, sand it off, and so on. I actually managed to get a thin spot in the plastic on one of the sides aft of the sponson, so I put a couple of layers of 1.5 oz. fiberglass cloth over the thin spot and all is well again.
                                The hull is amazingly stiff, yet light. Any flex in a hull absorbs power, so the stiffer the hull, the better. The epoxy mix holds razor-sharp edges. I'm thinking I may do the same "Jet Sauce" ride surfaces as I did on the Campbell shovel (colloidal graphite/epoxy mixture). It's a lot of extra work, but I think it does help reduce hydrodynamic drag.
                                I've decided to make vacuum-formed plastic vertical fins and wing. The fins will have two 1/16" SS wires sticking out of the bottom of the fin. These wires will go into 1/16" ID aluminum tubes that are set into the hull, making the fins "Plug-in" assemblies. The removable wing will be adjustable or fixed at the builder's option.
