1954 Breathless U-22 1/10 scale build Garry Finlay plan
  • studioRS
    • Jan 2009
    • 116
    Planning to build to Classic Thunder, e-rcu running gear and racing specs. TURN LEFT, right side rudder, 1/8" solid shaft, built up strut, PB 1500kv motor. I live up in Northern Vermont and don't see any racing action (yet...), keeping the same size as the plan with some mild changes in wood specs and running gear.
    Last boat I built was in 1992, a 1/16 Dumas Thiftway Too with Graupner Speed 600BB, Hughey running gear and six nicads. Ran it in Lake Tahoe where I lived.
    Jump in the Hot Tub Time machine and pop out in 1976, I worked for Charlie Pottol at Marine Specialties in Saratoga, CA. used to race time trials at the perc ponds with Gary / Joel Johnson and NAMBA. So, I've been out of boats for a while, but I have been building sailplanes and flying still very much still involved in RC hobby. Glad to be able to post my RC enthusiasm.
    Cheers, Thompson
    Mitch D sent me some photos of his winning 1/10 scale hull and build back from 1999.
    Also sent me some of the real Breathless U-22 from his archive, he is THE man!
    Cheers, Thompson
    1/10 1954 Breathless U-22, Tahoe Yacht Club | 1/16 1958 Dumas Thiftway Too, built in '92
  • studioRS
    • Jan 2009
    • 116
    I've had the plans laser cut and added some lightening holes in the bulkheads. Also used 1/16 ply with 1/16" balsa laminate instead of 3/32 balsa with 1/64 ply. Substituted lightened 1/8" ply for the bulkheads and stringers instead of solid 1/8" balsa.
    This was my plan for setup and gear
    Motor: ProBoat A3630 1500kv
    Battery: 4S 5000mah 45C
    ESC: Turnigy Marine 120
    Rudder: Marine Specialties of course !
    Drive: 1/8" 316 stainless steel, built brass strut, Octura oilite bearings
    Prop: Graupner K45, K51 and Octura X447R
    Engine: Classichydros.com Allison V12 1710
    Wood: 1/32" Birch ply, 1/8" lite ply, 1/16" balsa, Sitka Spruce
    Glue: UHU Hart, Zap medium CA, kicker, Fiberglass
    Cheers, Thompson
    • studioRS
      • Jan 2009
      • 116
      Cheers, Thompson
      • studioRS
        • Jan 2009
        • 116
        Thanks Steve at OSE for the parts.
        Race ready goodness still to this day. Yeah, ok so it's not CNC, its vintage, retro and will match my build. Marine Specialties safety shear rudder, proudly Made in the USA. My old employer and I even have replacement teflon bushings I've been saving since 1977 - OMG!
        Cheers, Thompson
        • studioRS
          • Jan 2009
          • 116
          Built the rear hatch, sealed the insides with Systems Three epoxy, added a motor mount and started on installing the foam.
          Cheers, Thompson
          Cheers, Thompson
          • studioRS
            • Jan 2009
            • 116
            More photos...
            Cheers, Thompson
            • studioRS
              • Jan 2009
              • 116
              Just giving a heads up, classichydros.com has a new website and super easy to order eCommerce store with this new scale hydroplane kit available.
              Cheers, Thompson
              Expanded Short Kits include 1/16" deck skins and all bottom sheeting (tunnel sheet not shown).
              1954 Breathless U-22 (no air traps, squared off top deck).
              1959+ Style with air traps and rounded top deck. Comes with Wayfarers Club Lady fin.
              Short Kits framing only with rear hatch
              1959+ Style
              Cheers, Thompson
              • studioRS
                • Jan 2009
                • 116
                More progress photos, getting caught up here, sorry have been busy building :-)
                Status- the hull is actually finished and getting painted today, all hardware has been fitted and should be ready for final assembly this week. Off to Lake Tahoe next for the maiden!
                Cheers, Thompson
                Test fitting the decks.
                Cheers, Thompson
                • studioRS
                  • Jan 2009
                  • 116
                  More progress...
                  Cheers, Thompson
                  • studioRS
                    • Jan 2009
                    • 116
                    Dashboard building...
                    Cheers, Thompson
                    • studioRS
                      • Jan 2009
                      • 116
                      Propshaft is set at 6.9 degrees.
                      Front bow dam
                      Cheers, Thompson
                      • studioRS
                        • Jan 2009
                        • 116
                        Sealed the hull outsides with Systems 3 Epoxy.
                        While the hull was out for priming for paint, I dug into the Classichydros.com Allison V-1710 engine.
                        The intake manifolds require some creative sanding to match the real Allison.
                        Cheers, Thompson
                        • studioRS
                          • Jan 2009
                          • 116
                          Back from the painter, I got the job of sanding primer every night...
                          1/10 scale highly über kewl Tamiya 4WD driver kit modified with home made life vest, 1954 backdated helmet, scratch built goggles, leather side straps, cloth wrapped wheel. As aplus, the laser cut wheel is included in the kit from Classichydros.com
                          To make the goggles I used a photo from John Surtees F1 driver, but I actually do have a pair from my ski racing days :-)
                          Turnigy Marine 120A fits nicely into an old Apple Magic Mouse clear box. Should seal up well with some hatch tape.
                          More photos to come after I get it back from paint. Cheers, Thompson
                          Cheers, Thompson
                          • studioRS
                            • Jan 2009
                            • 116
                            Came out a little darker than I wanted, but looks nice. Under a sunny light blue sky it should pop and look a little lighter. Time to unmask the bottom and mask over the blue so it can be clear coated underneath.
                            Cheers, Thompson
                            • electric
                              • 1973
                              Looking good!
