I'm just going to run a cheap chinese outrunner somewhere about 800kv, 4s lipo, not sure of the esc, probably a used proboat or aquacraft, maybe a chinese 60 amp.
All the scale props I've looked into seem to be limited to under 13000 rpm, for pulling power I've been told you want larger diameter, low pitch, lower rpm.
I have a couple 1500kv motors that I was thinking about using on 2s but decided to go with a lower kv and higher voltage to keep the amp draw down, especially if I run an outrunner without water cooling. Should run much cooler.
I'm not sure how well water cooling will work at slow speeds so I wanted to keep the power system as lightly loaded as possible, if things get too hot I have enough room to install a small pump.
Gotta get back on that build, got side tracked with a new Whiplash hydro kit, and have been working out the logic for an unusual for electric twin build. LOL and picking up another 29" mono project this weekend.
Long Canadian winters, gotta have lots of projects. Build all winter, run all summer. Getting less than 9 hours of daylight now. Plus I usually work nights in the winter, on call 24/7 from November to April 15.
LOL I'm borderline computer illiterate, still can't post a youtube link in a post properly. I'll upload a couple pics of the LB, hope I can get the size right this time! Somehow last time my pictures were way too big, took forever to load.
