Delta Force 26
  • 785boats
    Wet Track Racing
    • 3423
    Hi guys.
    Quite a few guys in our club run these hulls , me included. We've found that if there is too much negative angle in the strut/stinger, they will dive easily.
    Another factor is that most stingers are too long for these hulls & need to be shortened. I've taken 15mm off the two that I've built with stingers. With the other ones, I used a strut set up as they are shorter than a stinger to start with. Shortening the stinger makes a huge difference in the handling of these boats.
    Cheers.
    Paul.
    • martin
      • 2881
      Originally posted by jfabcustom View Post
      Hey Martin, my DF hasn't done much diving. Only a few times when I had the stinger angle too negative. As of now I have the stinger and tabs neutral and the CG is around 30%. I found that even the smallest CG adjustments make a big difference, not only in the straights but in turning aswell. Hope this helps.
      Dana and Martin, what props are you guys running?
      Im still looking at building the DF 26.
      • dana
        • Mar 2010
        • 3660
        I agree with the comments above. Strut angle and trim tabs angle are crucial, and even small adjustments make a huge difference on this boat. Just a matter of finding the right spot. I also use a strut in a flood chamber on mine, with a very slight positive angle on my strut. Props are x440 x440/3(fav) x640 and x444(fastest)
        • jfabcustom
          Speed addict!
          • 108
          Hi guys.
          Cheers.
          Paul.
          Paul, good point. On both builds my stingers have been shortened. I wanna say I took off as much as 3/4 of an inch. If I had it to do a third time I would use a strut instead of a stinger.
          Sixty percent of the time, It works, Everytime!
