HPR115 Bulletproof Build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    #61
    Originally posted by Chrisg81983 View Post
    Kent if u need some serious power use my 3080's I got here is a pic of 1 but I do have two of these bad boys
    LOVE IT!!!! you are truely a Deuche B** LOL LOL I'm still laughing.....
    • lavigna
      Adam
      • Aug 2011
      • 50
      #62
      Coming along nicely. I am currently mounting the rudder on my build.
      Where do you order your SS screws?
      • Chrisg81983
        • Jul 2011
        • 1585
        #63
        Microfastners.com or ebay
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1876
          #64
          Ok Guys uploading photos from computer, then writing on iPad....
          Ok, got drives done. Another one of those things I don't like doing. But I use a metal file and clamp it against a piece of wood while spinning it in a drill. That way I can just shave off as much as I need. Also glued the main 4 blocks that holds the servo, and cover ESC's the other 4 blocks gets glued in when the epoxy sets. The need a slight different approach. I would consider her almost done. Just have to go over everything, thread lock the screws and waterproof a few areas just incase any leaks.
          drivesglued.jpggrinding.jpginside hull carbon.jpgmounting blocks.jpgrudder on.jpg
          • Xcesive8
            • Jul 2009
            • 439
            #65
            Hey Kent, Coming along very well..!
            Where do you get your mounting post that you have in your carbon washers?
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1876
              #66
              Hey, got them from Australian fasteners. Most of those guys should have something similar.
              • Chrisg81983
                • Jul 2011
                • 1585
                #67
                Yeah man looking great
                • ManuelW
                  • Oct 2010
                  • 786
                  #68
                  sorry for the Spam but here my idea about how a 3080 looks like (by the way the motor on the right is already a 2240..)
                  @ Kent: Beautiful work on the interior! Maybe you also put some color below the "HPR 115" letters in the center sheet?
                  regards,
                  Manuel
                  • Chrisg81983
                    • Jul 2011
                    • 1585
                    #69
                    @ manuel you had to go ruin my fun messing with kent LOL so what do u plan on using them for
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1876
                      #70
                      @ Manuel, yep there will be color under the HPR but I didn't install it yet, as I still need to trim and make it look neat. My first thought was to have a color panel that lights up when ESC's are armed. I'm still looking into that option as I have a few backlid displayes sitting around.
                      • keithbradley
                        • 3671
                        #71
                        Kent,
                        I just got some BECs in that use a remote arming switch that is operated by pin (BEC is not armed with pin removed). On the unit that the pin goes into, there is an LED that illuminates green when the ESC is armed, and has a LV warning that flashes the LED bright red. I wonder if you could use something like that to illuminate your letters? You could re-wire it to more LEDs, or perhaps just put it behind a lens so it lights the whole area...
                        Let me know if you want a link to what they look like. I made a post about them on the KB forum in the new products category.
                        www.keithbradleyboats.com
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1876
                          #72
                          @ Keith, was not going to use BEC, but rather just steal power out of RX from the aux CH. I have a white light panel used for TX backlid panel its around 1.5'x4' so going to try that with some translucent purple vinyl
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1876
                            #73
                            Got a bit more work done....
                            installed Motors, servo and a few bits...coming to an end.
                            • drwayne
                              • 3012
                              #74
                              Dont steal power from your Rx, it will cause grief.
                              Will only warn you once. !
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1876
                                #75
                                What, even to power a 50mah diode??? Servo will pull a couple of amps, how can a 50mah led hurt? Just asking....
                                The very short version will do hehe.
                                I could steal the power before it enter the Rx. But still keen to know why it's not ok.
