HPR115 Bulletproof Build
  • Chrisg81983
    • Jul 2011
    • 1585
    #46
    Teardrops look great kent. Just remember what I said about the ANODIZING u wanted to do that should sum it up for u lol. She looks great man keep us posted.
    • Jason4636
      • 712
      #47
      Very clean Kent. Looks great
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        #48
        Thanks guys for the comments. Got a bit more done this morning..... right side drive is in...phuu, that was hard and hardly any room for screwing in the motor. I should have done the famous twist n lock on the motor mounts because getting to the screws won't be easy. anyway... I'm quite happy with the result so far.
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1876
          #49
          ....and both installed!!
          • Chrisg81983
            • Jul 2011
            • 1585
            #50
            Looking good
              Beauty job my friend,beauty.
              • keithbradley
                • 3671
                #52
                Looks great!
                I'm starting to think I made a mistake not ordering the LKs. They definitley look cool in there!
                www.keithbradleyboats.com
                • Chrisg81983
                  • Jul 2011
                  • 1585
                  #53
                  Lk's r the way to go if you are spending the money on lehners in my op. Some time back I had two identical lehners but one was standard can and other was the lk, and I definitely saw a difference in temps. Anyways I will talk to u later kent
                  • ManuelW
                    • Oct 2010
                    • 786
                    #54
                    On SAW setups LK is not a must-have.
                    @ Kent: Maybe make the teardrop 1-2mm longer, may work already great as it is but this would may increase water flow! Everything else looks beautiful!
                    regards,
                    Manuel
                    • Cervelo
                      • 22
                      #55
                      Hello. Beautiful build your boat. Am enthusiastic about your work. Keep it up. Greetings from Germany.
                      Christian
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        #56
                        Welcome Christian, and thank you for the compliments. I always enjoy seeing you in here!! you builds sure are something out of this world, and a class of their own. But I'll try to keep it up and hopefully get something nice in the end, and reach some decent speeds. Are you done with the mystic? or starting other builds? Manuel's maybe?? hehe....
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1876
                          #57
                          Ok folks its been awhile since I have posted, but I have been too busy with other things (not even at the lake). The few new mods on the boat were going to be a pain in the A$$, so I was in no rush to do them. Anyway they are done now. To be able to fit the screws that hold the drives you have to grind a little/lot so you can fit the bolt/washer, grind too much and you have yourself an extra hole to worry about!! LOL. Keep in mind, everytime you loosen your drives for any reason, you should make sure you realign them to the sponsons. Don't take for granted they are striaght!! Also my stainless 45mm M3 screws arived so I could get them cut to the right lengh and mount the rudder as it should. I left 5mm thread on the screws.
                          • Chrisg81983
                            • Jul 2011
                            • 1585
                            #58
                            I had to do the same grinding kent but it all wrks out fine in the end. Keep up the great build man
                            • Chrisg81983
                              • Jul 2011
                              • 1585
                              #59
                              Kent if u need some serious power use my 3080's I got here is a pic of 1 but I do have two of these bad boys LOL HERE R THE THE BIG BOYS
                                Originally posted by chrisg81983 View Post
                                kent if u need some serious power use my 3080's i got here is a pic of 1 but i do have two of these bad boys
                                two???
