I bought this MG off this site's for sale area. I don't know if it was cause the packing, or if it had cracks in the hull before. But when I got it, it had 2 cracks. And an indention for a 3rd crack. It went thru my head to just sell it and get out of it. When I bought the boat, the same day I placed an order with OSE an Kintec for parts for the rebuild. The parts beat the boat, then the boat was a big disappointment. When I first saw the boat, I put it back up for sale. I tried to sell it as a package, but after 2 days. I decided to rebuild it and fix the hull.
Started out with filling in the water inlet & outlet holes, plus the antenna hole. With some cut up FG and resin mix on the inside. Then a little body filler on the outside, and sanded smooth.
Next up was the ride pads, I had to use some more filler to build up the area. They may not be the best looking rid pads, but there better than they was.
Next I pulled everything out of the inside of the boat. To give me more access to the inside. Took a dremal with the snake attachment and a sand paddle wheel and started Sanding down the old glue from the floor. Sanded down about 75% of the hull seam on the inside of the boat. Way to hard to get all the way up to the front of the sponsons. After the seam was sanded down, I layed some resin down, then some 2" FG tape, then on top of the tape. I put some more resin with cut up FG, lightly over the tape.
