Originally posted by fjelling
View Post
Zonda gets a face lift.
This topic is closed.
Yes I ran it in the basement to make shure the motors and servo are working. Next is the bath tub for leaks and them to banks lake for so test runs on 4s. If this goes well I will run though the boat and run 6s the next time out. I will find a way to get some vids so that your all happy.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
No this one is the zonda that is a rtr. I have ran it this summer until I seen the crack in the back where the rudder mounts. I ordered new motors and servo mount so that I would upgrade as well as fix the hull. This hull was 41'' long and is now 41 1/4'' long after installing the saddle. The rudder from the Genesis is now on this hull. I ordered a new rudder for the Genesis that is bigger and stronger
these pics are of the new one and is a 185mm rudder vs the 150mm you see here.
WARNING!!! THIS RUDDER REQUIRES A LOT OF MODIFICATIONS TO MAKE IT WORK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have it installed on the Genesis 4 hrs later!Last edited by twissted; 08-15-2013, 10:05 PM.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
Oh but the way the SSS3674 2075 out performs the Leopard 4074 2200kv motors. faster and longer run times. I will do one more test then they come out and are for sale!twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
I will work on that. for now I can say that you can see that they are slower and the run times are almost half. I can say that I was running 4 batteries 1 front of the motor and one behind. with the 3674 motors I ran a single 6s behind the motor only. So the boat may be running to wet. That will be my next test.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
Last edited by twissted; 09-07-2013, 03:48 PM.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
I bought some new 6s lipos on ebay called Vortex X. They are so called nano's and are said to be 50-100c discharge. Well there NOT! There lucky to be 25-50c. I'm currently working on getting them replaced.
here is a video that I did today that shows them running with the stock 40mm cnc props that I sharpened and polished. the rest you should know.
I think its time to go to 8s with this hull. I have some motors that I have been wanting to try. they are the HK mad thrust 4074 1200kv motors that are made to run with 6-8s lipos.
I want to try them with the Castle Ice 200 or 240 esc's I'm thinking the 240's just in case I need them for my Genesis build. I aslo want to try some 50mm 3 blade props with this set up.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
I picked up two TP power water jacket to see if they fit my Mad Thrust Motors
The ones off of my Leopard 4074 motor are to small in diameter.
I hope these work.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
