Next build: 37" Komodo
  • tagasagwan
    Molino Boater!!!
    • 995
    Originally posted by HYDROJERRY View Post
    O crap i better start selling stuff now,,hahahaha
    Hahaha! I'm ahead of you bud! I already sold my SM29. The one on my avatar and trying to sell a couple more boats. Oh crap! I should change my avatar now! My SM29 was Mac's ever first FE boat hull build. I will definitely regret selling it! It was our first project when we got to know each other.
    My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
    MHZ Micro Iceberg, Skunksworks Gen2 Cat twin, Aquacraft SV27, SM29 1515 sold.
    • RCKong
      • Sep 2009
      • 1680
      Hey bro looks like an easy fix on the stingers you have... it involves a bunch of filing though (typical). Take off your adjustment rod and grind down the top of the mount
      until the stinger is level or just under the sponson. file down the sides of the mount until you can clear the adjustment rod on the top of the mount. Drill a new hole for it and it should fit nicely. Hope it helps.
        Thanks Brian,I already picked up a 2.5mm tap and drill bit for that task exactly.Those are bolts in either side on the top part of the arm.So I am off to the drill press.I don't see too much harm in changing that angle. Oh and filing...NOT
        • tagasagwan
          Molino Boater!!!
          • 995
          looks like you're ready for any battle that the Komodo will throw at yah!
          • tagasagwan
            Molino Boater!!!
            • 995
            #35
            Well Here is a pick of these nice little powertrims
            But as you can see there is a problem
            I'm going to try to buy 4mm from these little guys by moving the arm toward the ball socket/pivot point.
            My other option here would be to cut the floor of the hull to gain room and glass it back in.Which also wouldn't be the end of the world but...
            I see the problem Shawn. Cutting it and glassing it may do the trick. A lot of work but it can be done. I'll give Mardon a ring and discuss this. Maybe we can adjust the mold and add 5-7mm relief to it so to give the Komodo some versatility when it comes to stinger choices. We can fill the area in the mold so that the next full will have the desired relief. Do you think that the overhung needs some relief too? if so, how much?
              It wouldn't hurt Stephen,I was looking at these stingers but that is a bit pricey http://mbp-rc.de/click-drive_1 139 euro is a bit much a piece.But I think the rear mount would work with maybe a round cut out where the pedestal goes thru and a CF sheet adhered inside on the deck floor.This is probably easier to envision with it in front of me.
              BTW New holes drilled and tapped.
              • tagasagwan
                Molino Boater!!!
                • 995
                #37
                Those stingers are really cool but the price is burning HOT!
                • tagasagwan
                  Molino Boater!!!
                  • 995
                  #38
                  Shawn, this is nice too for $35 smuckaroons. http://www.ebay.com/itm/108mm-adjust...item20c82a2f40
                  Plus you can install the base sideways or a bit angled to fit. the problem is, it might be too long at 108mm.
                  • RayR
                    @SiestaKey.calm
                    • Jun 2007
                    • 1591
                    #39
                    These are 24mm tall and 34 mm wide and 70 mm long
                    http://www.ebay.com/itm/70mm-adjusta...item1e60e7f313
                      That was a thought that came to me in the night Ray as I just put some on my Geico twin.Still need to be modified to 3/16 from 4mm though.I did successfully accomplish this once(twice I mean) but don't know if I would again with my tools.
                        So I got an update on the stingers: first i marked them both where I needed to drill
                        I then center punched and then went to the drill press(located across town)
                        I then tapped the holes and trimmed the necessary metal to make the arms fit
                        And trimmed excess metal off giving me my 4mm of clearance.
                        Now to match some tubing to the mount hole and move to the interior.I have ordered a scale 150mm rudder for this.They claim I will see it in a week so I better get on the CF layup and motor mounts and such.
                        Change:I don't think I will do a CF layup,this hull is plenty strong.
                        • tagasagwan
                          Molino Boater!!!
                          • 995
                          #42
                          Looking good bro!
                          • RayR
                            @SiestaKey.calm
                            • Jun 2007
                            • 1591
                            #43
                            It's nice having Dave from HRC in our club, he's got all the right stuff for reaming out a strut.
                              I'll tell ya,there wasn't much meat left there.I did oversize the hole,put a brass tube in and then a Speedmaster 21 bushing.Works great though.
                              • RCKong
                                • Sep 2009
                                • 1680
                                #45
                                Now thats what I'm talking about, nice job on the stingers... those will work for sure, and look heavy duty. where jou get'um ?
