HOR 41" Zonda twin cat build
  • sampit
    • Jul 2009
    • 466
    The water line goes from the rudder to a three way splitter each one feeding an esc and motor it has two outlets one in each sponsons
    I'm going to change it might get another three way splitter a send it all in to one esc then the other and only use one outlet
    I'm not sure if each esc would get even water flow the way it is now maybe ok for the T120 escs
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
    • sampit
      • Jul 2009
      • 466
      2.4 radio works with no problems with range issues
      Fm might be dodgy!
      Same Kevlar hull as my Cheetah works great!
      • sampit
        • Jul 2009
        • 466
        Had another close look at the hull it think it might be all Kevlar and no glass
        There's no joining seems and the top i think is also Kevlar not 100%
        Would need a second option
        • twissted
          • 896
          I have mirror that is pretty handy for this kind of thing.
          twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
          • twissted
            • 896
            So could you show the stingers?
            • sampit
              • Jul 2009
              • 466
              • twissted
                • 896
                So you don't like the motors that it came with?
                • LOVE6S
                  • May 2012
                  • 538
                  Sam, how much was the boat with shipping, minus motors and esc's? Did you have to call them to get it that way?
                  • keithbradley
                    • 3671
                    Originally posted by sampit View Post
                    Thanks Keith,
                    Do you think the setup will work, I followed your lead when you bought these motors last year, it worries me a bit because i think you sold them
                    I still have 4 of them, just haven't gotten around to building anything with them yet. They should work well. Keep the props small and the timing low.
                    I did notice some problems with certain ESCs when using higher timing and somewhat high RPMs. On 4s you should be fine if you keep the timing down...it still doesn't hurt to do a bench test on any setup though.
                    www.keithbradleyboats.com
                    • sampit
                      • Jul 2009
                      • 466
                      Thanks, just waiting for the other motor to turn up
                      I Set the timing to 3 and set the PWM at 8 on both escs
                      I have soldered together the two black 8AWG esc leads in to a 8mm bullet
                      but not happy the wires are to thick to get a nice solid connection
                      What do You think I need to make a set of 8mm esc connectors ?
                      or can I buy them?
                      Might be ok on the battery side,hard wiring both black and both red lipo leads in to two 8 mm bullets
                      Because I have conected the two escs together on the FC escs do I just use a
                      Y lead?
                      and do I need to remove one of the red wire?
                      • twissted
                        • 896
                        • twissted
                          • 896
                          Does this help you?
                          • keithbradley
                            • 3671
                            Twissted:
                            If you want to post other people's pics to a thread, you can link to the original, or if you pull the pic you should let people know where you got it.
                            • twissted
                              • 896
                              Ok I'll do that. I pulled these from my photobucket files.
                              • keithbradley
                                • 3671
                                Why do you have my pictures in your photobucket files?
                                That's the third boat you have posted pics of that I have built.
