Well I bit the bullet a bought myself a HOR RTR hull less the motors and less the escs, arrived safley in a 3 days
the price was good and a cheeper option hopfully be running a little quicker than a full build.
I indend to use two Fightercat 300A 2/6s risky I know but no other choise as Fightercat keeps ignoring my emails redarding the reliability problems some folks have had with these escs, so hopfully be running on 8000Mah 35c/70c
2x4000 packs hard wired in parallle. or maybe better on 3s2p and smaller props for a little less RMP
Motors are the Trackstar 6 pole 4069 2650kv custom macined to fit 40mm x 40mm Leopard water jackets
the Props that came with the hull are 42mm CR CNC
Apart from the mototor mounts being set a long way forward this makes it hard not to run the lipos on the tunnel floor without more work moving the mount back to run the packs in the spoonsons, as its not really being build to handle but just fast staight runs im hoping I can get awy with it at lest for the time being.
I got the escs timming set at 10 degrees not to sure if this is right ? also need help with the pw setting?(CANT REMBER WHAT ITS CALLED) without looking setting is either 8 or 16, I think most motors run on the 8 but im not sure if I reed that these motors need to be set at the 16 setting?
Any help or a Mentor would be a great help, do you think the setup is a bit hot for a 4s setup, any idea of speed? I am sue these motor were ratted at 2560kv when I bought the first one.
more to follow with a few pictures at the setup.
