New Stealth hydro
  • longballlumber
    • 3417
    Hey Phil,
    Mike Ball here... I plan on selling mine this fall and buying the new hull for another winter build. Like Darin mentioned, I have some more ideas about getting it set up for that extra performance/stablitity.
    Later,
    Ball
    • phil t
      • Feb 2010
      • 195
      Originally posted by detox View Post
      By flattening the hull floor I bet there is less interior room. This will be a perfect LSH hull.
      There was no change to the inside hull.
      Phil Thomas
      email supersport45@aol.com
      http://www.philthomashydros.com
      • phil t
        • Feb 2010
        • 195
        Originally posted by longballlumber View Post
        Hey Phil,
        Later,
        Ball
        Sounds good, i see that water jacket on your motor I had that on my motor and it had almost no water flow, checked it with a flow meter, I changed it out to a Aquacraft motley crew jacket and it was wide open.
        I would set the motor up to the back of the batteries and fit the esc in the left deck, you will save some ballast weight there.
        How deep are these struts you guys are running.
        Trimming a sport boat is all about weight and balance point and strut depth and angle, set it to what ever it takes to run with out blow off, once it is close just a small bit of weight to fine tune to conditions.
        Phil Thomas
        • RaceMechaniX
          • 3024
          Here are some additional pics of the Stealth Brian built for me. These are shown with the P system that set the 2-lap record although a 32.200 was used instead of the 24.150. To say the hull was overpowered would be an understatement. This set-up was running 70 mph at the end of the straight with a long run up. Believe it or not it was not pulling huge power numbers, but it was spinning the X440/3 pretty high.
          Brian has his dialed for P-spec and was visibly quicker than Darin's and mine. He blew the old P-spec record by several seconds. I just got lucky and had good water when I set the P record, I know Brian probably would have edged me out given more time and better water.
          We had great fun with these hulls.
          Tyler
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • detox
            • 2357
            Tyler, I really like that color yellow. What color yellow is it?
            OH YEA...how much does your hull weigh ready to run?
            • longballlumber
              • 3417
              Thanks for posting pictures Tyler,
              Were you guys using the same battery configuation in P Sport Hydro as you were in P-Limited Sport Hydro? If so that would explain your abiltiy to have the motor in the same place for both classes and maintaining the balance of the boat for both classes.
              Thanks
              Mike
              • Shooter
                Team Mojo
                • Jun 2009
                • 2751
                Phil - Do you recall the flow rates you measured? Thanks.
                • RaceMechaniX
                  • 3024
                  Detox, Brian painted the hull and off hand I do not recall what exact formula it was. Something similar to a Honda Canary yellow with metal flake. Looks great in the sun.
                  Mike,
                  For the 2-lap I ran 4S2P 10Ah total mostly for the weight. I did have the drop the strut significantly and increase the camber on the turning too. I did not run this setup for P sport at the Nats, instead I was using a Neu 1515 1Y. It did take a lot of lift decreasing to get the P sport to stay on the water. For P spec the setup runs quite good. I ran 4S2P 8.4Ah total for P spec. I could have run 4S1P, but the 2S packs were being used on the same day for an N2 class.
                  Tyler
                  Tyler Garrard
                  • properchopper
                    rcgoatbuild@snotmail.com
                    • 7708
                    There's a very important lesson here, often overlooked by many of us (myself included). It involves learning how to setup/tune a boat. Watching the early practice runs of the three PT's brought to the Nat's by Brian, Darin, and Tyler I wasn't impressed and actually thought I had a good chance of scoring well in both P-Sport and P-Ltd. By conscientious application of tuning practices, Messers B,D, & T soon had these boats at the top of their game and kicking some serious butt. There's no short-cut to achieving results and, having personally witnessed this, I, now more than ever need to remember this. So should we all.
                    • detox
                      • 2357
                      I just put my order in for one of these.
                      • phil t
                        • Feb 2010
                        • 195
                        Dont know if it means anything to you but on a Boris meter it was 20-30,, wide open is 0. 40 would be a needle setting rich on a nitro motor so it would be very small amount of flow.
                        Phil Thomas
                          Just ran my painted PTSS this weekend and I use no lead. Instead I use Turnigy Nanotech 7.6AH 2s2P x2 Lipos and the extra weight keeps it planted .... unless like in the last heat I heated up my lipos before the race and wholly molly, staging the start I punched it and she blew over from the power and it was a calm day to boot.
                          Usually it was just fine until I "turned on" my cells by heating them to 120F before the run.... now, maybe some weight, 2-4 oz's at most
                          Nice new boat Phil!
                          Maybe this winter...
                          • detox
                            • 2357
                            Phil, Does it matter which side of stern you mount rudder. I see most people mount rudder on the lefthand side because of less linkage flex. Have you ever noticed a difference in handling Right vs. Left.
                            JFYI i have been using the High Tech Mighty Mini Servo in my 30" hydro for some time now without fail. Rudder is mounted on right side of stern using 440 rod (pushing action to turn right)
                            http://www3.towerhobbies.com/cgi-bin...&I=LXN667&P=ML
                            • detox
                              • 2357
                              I found this Turfin info very helpfull when balancing my hull. Imagine a string being tied to center of turnfin while cornering. Much like the old string driven airplanes going round and round. Air flowing underneath hull also plays big roll. I like balance slightly tail heavy.
                              Originally posted by Scott Schneider
                              Mike,
                              In the hydro world, best way to get a handle on hull attitude with turn fin placement changes is PICK BOAT UP by the turn fin.
                              Now while cornering hull is pivoting / hanging by the fin.
                              So a fin too far forward has hulls tail heavier that the front and hull will YAW hard having transom swinging around faster than the bow.
                              Fin too far back places bow heavier than tail and hull will seam to push like a race car does with a straight axle not wanting to set up and get around the corner.
                              When placement is correct tail should follow the bow as if hull is swinging on a string while balanced right in the middle.
                              ** Tuck angle having fins lower edge tilted towards hull places the water pressure of the sliding fin to climb the angle and this pressure tends to pull the hull downward at the same time.
                              • phil t
                                • Feb 2010
                                • 195
                                The left side mount is common on sport boats, linkage is a pull for right turns and helps hold the turn fin in the water. You can put it on the right let me know how it races like that.
                                The 225 is good servo for rudder.
                                Phil Thomas
