Hpr 06 / 115 build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1837
    #106
    Oh oh, when is the graphics going on?
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1837
      #107
      Originally posted by Chrisg81983 View Post
      Thanks Shawn I think they are a nice lil addition I am glad I bought them
      Question does anybody have any advise on what the best way to seal where the cable for the hydraulics enter the hull ?
      Thanks
      You should run the wires inside antenna tube if you can, and the antenna tube stuck to the hull. Can also Grease inside the tube so it all runs smooth. That way you definetly won't have any issues.
      • Chrisg81983
        • Jul 2011
        • 1556
        #108
        Tonight I did some playing for an hour or so but got one more thing done I installed the air scoop. I first put in place on top of hatch and drillers a small pilot hole into the scoop and through the top of hatch. I then threaded the scoop with a 4 mm tap enabling me to screw the scoop down along with gluing it. I don't think this thing is going anywhere without braking then hatchb first, but we will see what happens. I also started working on another set of hatch bolt done making a total of 6 now. I have another delay now as well I decided to go with 5mm flexes. I now need to get new larger brass, Teflon, clutches from mbp, and new prop shafts as well. Here are some pics of the progress
        • Chrisg81983
          • Jul 2011
          • 1556
          #109
          Well well look what I got today !!! A set of 2240/7's with matching jackets and tail rings along with 15 sets of lmt 6mm connectors
            • 7651
            #110
            There we go.Time to get her wet?Yet?
            • Chrisg81983
              • Jul 2011
              • 1556
              #111
              Well I could start but I need to wait a week or so as i decided not to use the 3/16 / 4.75 flexes. I just ordered new clutches from mbp i also got some l&r 5mm flex with suitable brass and teflon for the build. So that where i am at now i might be selling the clutches that i earlier posted in my build so if anyone is interested in them let me know
              • Chrisg81983
                • Jul 2011
                • 1556
                #112
                Ok well i did some laying out of the power system what do u think
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  #113
                  Yes me me... I want :)
                  By the way.. looking good. Dont you just love the feel of the Lehners LOL no loose ends or moving shaft. Just rock solid all the way through
                  • Chrisg81983
                    • Jul 2011
                    • 1556
                    #114
                    K they are yours we will work out something for them don't worry. Yes the lehners are so precise it's feels good to finally have a set it's like your first new car lol.
                      • 7651
                      #115
                      OK guys,clutches?Mmm,this is new to me.Don't we have hard and soft start for this on our ESC's.
                        • 7651
                        #116
                        Chris,have you checked out how I laid my Shocker ESC's out.Much shorter wires,just sayin...
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1837
                          #117
                          I'm sure Chris will sort out the wire thing, but those esc's need to come more towards rear anyway. Remember Chris, if you run the Lehners in Star mode you can run higher voltage and pull less amps. If you run in star you got about 1233kv so 8s could work running mid 30k rpm just a thought.
                          • Chrisg81983
                            • Jul 2011
                            • 1556
                            #118
                            Shawn clutches is just a fancy word for collets i was planning on running tge esc's back a few more inches to minimize wire length. Shawn off the top of my head i cant remember what you did with your esc's. Kent the only thing with running a higher cell count is that my lipo trays will not work
                              • 7651
                              #119
                              This is what I did with my ESC's Chris.
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1837
                                #120
                                You can run 4s 6800-7200mah per side into 8s no? I'm sure that will fit?
