Hpr 06 / 115 build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1837
    #136
    Very nice Chris, really look forward to see the finished result.
    • Chrisg81983
      • Jul 2011
      • 1556
      #137
      Thanks Kent me too....... last night I bored out the back of the drives from 8 to 9 mm it came out pretty good I will get some pictures up of the work real soon
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        #138
        Pictures?? I would like to upgrade to 1/4 flex so curious to see how you managed that 1mm :)
        • Chrisg81983
          • Jul 2011
          • 1556
          #139
          Here you go it was fairly simple I did it with a standard drill press while I thought I was gonna need to use a lathe
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1837
            #140
            Ouch...dont think you can do that on the MHZ drives hmm, maybe I need the 1/4 version. 3/16 is ok, but we are putting a fair bit of power througn the drives. What is the benefit of the 5mm Chris.? 3/16 is 4.76 already.
            • Chrisg81983
              • Jul 2011
              • 1556
              #141
              Kent I have been talking to Manuel an he stated that he had some problems with standard 3/16 flex. He uses the 5mm in his own build along with his high performance builds. I figured it's much easier to address the issue now rather than later
              • Chrisg81983
                • Jul 2011
                • 1556
                #142
                Maybe Manuel can give more specific info on this matter thanks
                • ManuelW
                  • Oct 2010
                  • 743
                  #143
                  Mhh the difference in diameter is not big (4.75 vs 5mm) but they are in my eyes better manufactured and have a little different winding and thicker strands. The biggest I've run on these was a set of PropShop 5517/3 at around 38.000rpm. I assume a standard 3/16" shaft will more look like a cork screw if you try that.
                  regards,
                  manuel
                  • Chrisg81983
                    • Jul 2011
                    • 1556
                    #144
                    Thanks for the info Manuel
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1837
                      #145
                      Oh nice, in that case I might be able to use those, now where can I get em
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1837
                        #146
                        Chris, did you get them locally or Germany?
                        • Chrisg81983
                          • Jul 2011
                          • 1556
                          #147
                          I believe the company who makes the ones I am getting is GUNDERT Manuel is getting them for me as I needed a few other parts as well so he is helping me out with everything that is needed to do the switch from 3/16 to 5mm and some extra things like a savox 1251mg and so on
                          • Chrisg81983
                            • Jul 2011
                            • 1556
                            #148
                            Well she left for paint last night.... I really wanted to wait until the boat was completely built then strip back down, but things got delayed with the build. Plus I called my appointment date once with my painter so delaying it again was totaly out of the question. I should have it back in a week or so
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #149
                              Oh YEAH!! now your talking Chris, Just cover her up while working and paint should be fine :) Atleast you can get those fancy decals tested :)
                              • Chrisg81983
                                • Jul 2011
                                • 1556
                                #150
                                That's what I am saying I need to show off you fancy work I couldn't see putting them over the gloat the. Wasting the vinyl a month or so down the road when I decided to get it painted so I guess it all worked out but my plan is to cover the entire hull with painters tape once I get it back
