MHZ Mystic 1380mm build
  • ManuelW
    • Oct 2010
    • 743
    #556
    Hi Kent,
    just as a hint, running partial throttle like 75% with a 100mph setup can be quite dangerous either to ESC or motor. I'd recommend either to start with smaller props which makes it easy for 100% throttle or simply dare to do it. Partial throttle will stress your components way more than giving 100% throttle and creates also a lot of heat.
    regards,
    Manuel
    • MrUnlimited
      • Jan 2011
      • 94
      #557
      Look what came in today by Fedex:
      Next step wll be cleanng the hull and prep for painting. I also ordered decals wth it.
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        #558
        [ATTACH=CONFIG]86052[/ATTACH]
        [ATTACH=CONFIG]86053[/ATTACH]
        Well well well, NICE! what size? you'll have a lot of fun I'm sure
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1837
          #559
          Hello folks, a couple of highlights from the weekend...
          first run on 6s second on 8s at a solid 92mph...
            • 7651
            #560
            Right on Kent,that's better.A little more room there to open it up.
            • MrUnlimited
              • Jan 2011
              • 94
              #561
              It is the 1380mm hull
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1837
                #562
                Cool! hope you do a build thread on her, what sort of hardware do you have in mind?
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  #563
                  Just a action shoot :)
                  • MrUnlimited
                    • Jan 2011
                    • 94
                    #564
                    MHZ has the rght stuff for her: 1/4" flex shaft right and left. MHZ rudder and "hydraulc" steeringdummies, Trimax by MHZ. Powerplants will be 2x Proteus motors 910KV on 10s lipo. I am wainting for an answer of Skyrc for their new high voltage Swordfish esc. They are working at it. Props will be done by Andy Brown (L&R props). I'll also have plans to watercool the lipo's although they perform better when they are a little bit warm.
                    As for the buildng thread, I own an url which will be used a website or buildingblog.
                    • drwayne
                      • 2977
                      #565
                      SKYRC has no relationship with products from Hifei of ChongQuin 重庆
                      That said, I am interested in any reviews you would give these units, if you chose that path.
                      regs
                      DrW
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1837
                        #566
                        Hello folks, just some updates....I have glued in the new 5mm flex cables instead of the 3/16's looks to be a big difference! I also got the nice collets from model boat pirate. Have also stripped the hull tonight and started sanding. "Time for a nice paint job" should have her ready in about a week or so?
                        • MrUnlimited
                          • Jan 2011
                          • 94
                          #567
                          regs
                          DrW
                          Wayne, Hifei has indeed no relationships to Sktrc but in my opinon it is free to use the name swordfish for an esc by any company unless it is registrated name. Skyrc has already an esc called Swordfish: http://www.skyrc.com/index.php?route...product_id=111
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            #568
                            Hey Folks,
                            She's at the painters for a spray tan, gotta keep em happy! Should get her back on Friday for decals and ready for a Sunday drive....
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #569
                              Hello, now that she is at the painters ive been working a abit on the new design. Someone has to be the first right? I always like simple layouts so I'm trying this one soon as I get her back.
                                • 7651
                                #570
                                I like it!!!
