MHZ Mystic 1380mm build
  • keithbradley
    • 3671
    #511
    Kent,
    Are you using anything as a means of disconnecting power from the outside of the hull?
    www.keithbradleyboats.com
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1876
      #512
      Kent,
      Nope, not yet. I'm thinking of the magnetic connectors but not convinced.
      • Chrisg81983
        • Jul 2011
        • 1585
        #513
        Kent do u have a link to the ones u were thinking of using
        • keithbradley
          • 3671
          #514
          Manuel said in another thread that the magnetic ones MHZ sell weren't water proof...that's a bit concerning.
          I would like to find something nice. If something ever happened close to shore it would be worth it to be able to minimize the damage.
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            #515
            Your only safe way is what doc is doing. Take the main power off, you have to brake the main battery connection and have 2 terminals through the hull that way it's definetly off. Not just connection to reciever.
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1876
              #516
              That's why hesitant to get them. I don't recall they were MHZ? There was a mod or something to make them waterproof.
              • keithbradley
                • 3671
                #517
                Your only safe way is what doc is doing. Take the main power off, you have to brake the main battery connection and have 2 terminals put the hull that way it's definetly off. Not just connection to reciever.
                Is the MHZ one just rx connection? That would be pointless in my opinion.
                I agree, you want to open the circuit with anything you use.
                I've considered mounting bullets, but on a carbon fiber hull they would need to be insulated to prevent conducting through the CF.
                • keithbradley
                  • 3671
                  #518
                  This is the MHZ switch:
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1876
                    #519
                    Sorry Chris, no link.....I saw it on a few German boats. I might not go down that path. Maybe internal fire extinguisher on channel 3-4? Just a thought LOL
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1876
                      #520
                      Originally posted by MrUnlimited View Post
                      I found some serious powerhouses for the new hull: http://www.lightinthebox.com/skyrc-p...t_p385540.html
                      Could be ok if they hold up. If not scared, just buy and let us all know. Concept like the Lehner motors. Would be interesting to see if they hold up
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        #521
                        Yeh it's an rx one, prevents signal to esc so it can't fire. But if your problem is on t he main, or after a crash, you feel safer that you can disconnect the main..
                        That's what doc has bullets through the hull
                        • keithbradley
                          • 3671
                          #522
                          My concern would be more centered on preventing a meltdown if an ESC fails. Pulling the RX does nothing to prevent that, so maybe bullets are the best way. I'm surprised that no one make something to open the connection at the battery.
                          • drwayne
                            • 3012
                            #523
                            I went down that path of enquiry within Australian rules.
                            Any electrically operated disconnection would have weaknesses..
                            Rx wet sends wrong data ?
                            Flat/wet/shorted Rx battery wont power the disconnect or it's trigger.
                            The disconnects own battery fails.
                            Main pack shorts and welds disconnect's terminals closed..
                            ouch
                            We remained with the standard of deck plug set.
                            under CF decks I place a 1/4" nylon sheet as backing .. strong and non conductive... ( a kitchen cutting board is sacrificed to higher purposes ! )
                            around the female plugs through deck I use a plastic o-ring .. sits around the plug, ontop the nylon backing.. and CA in place.
                            Bullet proof ( excuse the pun )
                            anti-zap is always a nice feature when that zap will destroy plugs glued in the deck
                            I now MrK wont mine me hijacking his thread for a post... he hijacks many himself !
                            And yet people still forget to pull them out despite annoying repetitive reminders about safety and purpose.
                            Go figure..
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1876
                              #524
                              "And yet people still forget to pull them out despite annoying repetitive reminders about safety and purpose."
                              They should be there for your own good, so you don't go through the shredder and become fish food. Never assume people know your boat or the equipment running it. I myself have a habit of picking boats up from the front, so nowhere near props. I don't trust equipment, even with the power off. LOL
                              The day you forget the number 1 rule of logic is the day you get hurt! (Murphy's law is ther to get you)
                              I found that anything that can go wrong generally does go wrong sooner or later...
                              • drwayne
                                • 3012
                                #525
                                They arethere for your own good, so you don't go through the shredder and become fish food. Never assume people know your boat or the equipment running it. I myself have a habit of picking boats up from the front, so nowhere near props. I don't trust equipment, even with the power off. LOL.
                                It's possible some people are just immune to common sense, hey ?
