MHZ Mystic 1380mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1837
    #466
    Hmm took the girl out today with the new props. Nice props I must say!! She did just over 114km/h on 6s compared to 98km/h with the 4818/3. A little on the warm side though maybe 55c-60c there is no way I would try 8s, will cook things for sure. Maybe for 2 passes that's it. Will upload vid later. Sound of spinning those props is amazing.
    Here is a picture at the lake untill upload is complete
    • Chrisg81983
      • Jul 2011
      • 1556
      #467
      Looking real nice Mr Kent
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        #468
        Thank you Mr. Chris, today was awesome! Crank up your speakers and listen to those props cut!! It was the coolest. I'm easy to impress, can you tell? LOL
        • Chrisg81983
          • Jul 2011
          • 1556
          #469
          Yeah man it sounds awesome, and Chris works some nice props.
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1837
            #470
            The props rock, next I'll get some 457's cut to 52 detunged, s/b and slightly cupped! I think there is so much more in this boat! Can't wait for the 2280's want to be around the 100mph for fast and 75-80 for fun on the lake. It's plenty fast
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1837
              #471
              Here is a hi speed photo from the weekend :)
              • silver
                • 77
                #472
                nice nice great picture
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  #473
                  Thanks Jim,
                  Yours should be on the water really soon??
                  • MrUnlimited
                    • Jan 2011
                    • 94
                    #474
                    I am gonna purchase next month a new hull by MHZ Mystic c5000 1380mm. I like to know if someone can do a wrap for this hull (G3racing.com Aqua Mania). I also want to power this hull with 2x 6 lipo's and 2x Hobbywing Seaking 180A V3 esc. I thought to use these motors for it: http://www.tppower.c...ss_id=4&news=57 1260KV. Is it underpowered then or is it the right choice?
                    • Chrisg81983
                      • Jul 2011
                      • 1556
                      #475
                      Talk to Kent here for the vinyl wrap
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1837
                        #476
                        Thanks Chris, yep can speak to me about a wrap.
                        I think you can use the 180A controllers no problem. I would say, as long as you get a motor in the 56xx Class size (Big Leo or TP) "TP5650 Inrunner Brushless Motor 1600kv" more like it for 6s. You will have to run props in the high 50's- mid 60's range ???? (depending on amp draw) I would not power this hull with a 40mm motor. Always start with a small prop and work your way up.
                        • MrUnlimited
                          • Jan 2011
                          • 94
                          #477
                          I was thinking on using the 1250kv motors and use props with more pitch (pobably modified props) to gain higher speeds than 60's. I want to run at least 65mph or would a better choice with this setup a smaller hull such as the 1140mm hull
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            #478
                            I think the key here is spinning smaller props fast. 1250kv on 6s wont get you going very fast
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #479
                              Ok, new 5mm flex cables and collets shipped today (thanks to Manuel) will be a couple of weeks away. Hopefully by then the new Lehners will be here, and I can do some serious boating.
                              • drwayne
                                • 2977
                                #480
                                Have to step in here.. you talk of things like you have quantitative experiences.
                                @MrUnlimited 6S 1250Kv 30Krpm 4KW to x455/x460 and you may touch 65mph(110kmh) in the 138 for a sprint.
                                Finish that motivation decal you wanted to sell here.. post a pic for everyone to see !
