MHZ Mystic 1380mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1837
    #361
    Shawn, at one point you just gotta be happy? I think I'll be ok with 80-90mph that's still quite fast.
      • 7651
      #362
      Yeah if I can get that reliably I'll be happy.Then it will be time to go bigger and carry this knowledge along.Learning this prop stuff is fun to me.Oh,and the vid making.hehe
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        #363
        I hear ya shawn! I skipped a few steps and just wen bigger LOL
        Anyway, here are the mounts installed, first with some spots of epoxy, then Sikaflex along the sides. This should prevent the mounts from flying off in a crash. Dont look the best, but this is a step I won't compromise for looks :)
        I may do a second layer once dry, that way I can smoothen it all out.
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1837
          #364
          Build is on hold untill I get the parts from Germany......Come on DHL you slack B******* grrrrrr..... Good new is, I got props coming from propshop and Chris (dasboata) 57mm re to 52 S/B
            • 7651
            #365
            So which ones are you having done?Are you going for pitch?And I guess you mean 55's cut down.
            52's should be good on that hull.
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1837
              #366
              Chris (dasboata) is doing Octura L/R 457 reduced to 52 and what ever pitch that will end up being? from propshop its just their SS 5017/2 I just want something close to compare.
                • 7651
                #367
                Ah,I gotcha.I like my 5017's.I'm going to have to figure out this pitch change when cutting them down.
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  #368
                  Hello everyone, got the new AS26.150 EVO ll ESC's today all look cool. Only problem, I have spend all night trying to throttle calibrate them, with no luck.grrrrr anyone here know how to do it? Could it be the spektrum radio/reciever? Gotta blame something...... I'm usually ok with things like this, but these are wired.
                  • Chrisg81983
                    • Jul 2011
                    • 1556
                    #369
                    Hey Kent fir some reason with my spectrum radio I have to set the throttle trim down to about 95 % else some of my esc's won't calibrate I don't kniwvif thus Helios u but worth a shot
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1837
                      #370
                      Hmm I feel a little dumb, but then again not. I don't like to experiment with anything until I know it's ok to do so. I couldn't get those things to work and didn't know what to blame. When your convinced your doing it right and it don't work, you wonder. Anyway, I wasn't going to play with trims on the radio untill I knew I was doing the rest right. Make sense? It would just be more variables to worry about if the radio was set wrong. Anyway CONGRATS to Manuel. Magic word was 125% trim on throttle channel yeah!!. Got it right in first go. Not even a glitch!!. Now to the micro review ........ These things have controll!!! Pull the throttle gently and you can watch the shaft spin up from 0-whatever! Just as if you were turning them by hand. In other words it will spin the motors so slow you can watch them spin. Hit full throttle and motors instantly rew up. Sooooo we'll see how they perform on the lake.
                        • 7651
                        #371
                        Allright,somebody is HAPPY!!!
                        • Chrisg81983
                          • Jul 2011
                          • 1556
                          #372
                          That's funny that it's 125 percent !!!! That's what my spectrum dx3c has to be set at to work correctly with my hydra ices. Then for my yge's it needs to be at 96 percent. Did u get my pm I sent u of all the settings for a bunch of different controllers ?
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            #373
                            Nah? What PM. Didn't get it bud.
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #374
                              Ok, All seem to be working normal now. here is a look inside, and a video as well.
                                • 7651
                                #375
                                That is smooth Kent.Can't wait for the result.
