Got some more work done on this. Mocked up the second jet on the transom, gonna be sweet!!
Bolted up the second jet and traced out the locations for the water inlets. I cut out the inlets and sanded everything so I got a nice tight fit.
I chose the Traxxas 380 18turn motors for this hoping they would have a little more kick to them than the stock motor that goes in the decoy boat. However the correct couplers have been on back order for months so luckily my couplers from my KOS fit the prop shaft, but not the motor shaft. The motor shaft was smaller. I rummaged around and found some brass tube that fit over the motor shaft and inside the coupler. A little notch for the set screw and then I had a nice little adapter.
