Nikko boat twin jet drive conversion
  • dont slow down
    • Feb 2011
    • 125
    Got some more work done on this. Mocked up the second jet on the transom, gonna be sweet!!
    Bolted up the second jet and traced out the locations for the water inlets. I cut out the inlets and sanded everything so I got a nice tight fit.
    I chose the Traxxas 380 18turn motors for this hoping they would have a little more kick to them than the stock motor that goes in the decoy boat. However the correct couplers have been on back order for months so luckily my couplers from my KOS fit the prop shaft, but not the motor shaft. The motor shaft was smaller. I rummaged around and found some brass tube that fit over the motor shaft and inside the coupler. A little notch for the set screw and then I had a nice little adapter.
    Real men have shafts.
    • dont slow down
      • Feb 2011
      • 125
      Wouldn't ya know it, the damn couplers were too long. They didn't fit in the jet housing, so I had to cut them shorter. Man what a PITA that was, probably the hardest thing I've had to do yet in this build.
      After all that I was able to assemble one of the jets.
      Next step is to assemble the second jet and get everything mounted for a test fit of the bottom hull panel. Hopefully everything is right and it will fit right in. If all goes to plan then I will be putting the panel in for good. I plan to reinforce it plenty so it will hold up. Once that's in it will be a water-tight test to see if I have leaks. Then filler, paint, steering linkages, electronics and I'll probably wait till I get a maiden done to work on water cooling. That's it for now, hope to get some more time this week.
      • masonis1
        If you cant control it 👍👍
        • 1177
        Hope it turns out good.
        When speed isnt the option, change your ways
        • dont slow down
          • Feb 2011
          • 125
          Getting closer! Built up the second jet today after work.
          Bolted them up to the bottom panel for a test fit.
          After a test fit I realized I needed some reinforcing on the panel as it flexed quite a bit with both jets on there. A little angle styrene fixed that.
          After a bit of trimming it was time to bolt the jets to the transom and tack in the bottom with some glue. I started at the corners, then the middle of the sides and let it cure. Tomorrow I'll finish gluing everything along with more reinforcing on the seams.
          I'm going to have a problem where the original hull meets the new panel on the bottom of the boat. The original hull is a Vee style while the new panel is flat. I've created a piece to fill in the gap but I'm wondering about the new shape causing problems. Should I try to make some pieces to sort of blend the hull and bottom together? If I do I'm worried it would block the water inlets for the jets.
          • dont slow down
            • Feb 2011
            • 125
            Wired up the motors and ESC today, I'm going to have to tear down one of the jets. It seems I didn't get the motor shaft, coupler and impeller shaft perfectly inline. It binds at low speed so I'' have to try again. I also did the first float test to check for leaks. Got 1 small leak by the transom and the new bottom. Gotta get some more styrene and then start filling and smoothing out the hull. I also need some linkage for a "rudder" system. Getting close now!
            • masonis1
              • 1177
              Getting there
              • dont slow down
                • Feb 2011
                • 125
                Been pretty discouraged with this build the past few weeks. Been battling watertight integrity for the most part. I finally got it water tight and built the steering system. I put it all together, did a float check in the bath tub, and took it downstairs to the pond for a maiden. Let's just say there won't be any video. This thing is less than impressive. It was pretty windy but it wouldn't even make forward progress against the wind. Had my steering servo reversed and I'll have to readjust the whole steering system. A pretty disappointing maiden. Going to redo the steering and try again when it isn't windy but it still won't get on a plane that's for sure. I'll have to see if it will even be able to push another boat.
                  • 6057
                  Looks very nice!
                  • ryanjblajda
                    • 14
                    any updates?
