First build... Cheap boat, lots of power
  • masonis1
    If you cant control it 👍👍
    • 1177
    #1381
    2700kv
    When speed isnt the option, change your ways
    • seehuusen
      • Apr 2012
      • 101
      #1382
      pitch is distance travelled...
      37 x 1.4 x 4mm prop is what I use currently.
      so pitch is 37 x 1.4 = 51.8mm per revolution
      So in my case, on 3S:
      2500 x 11.1 x 51.8mm = 1437450 mm/min = 86.247 km/h (~53.59mph)
      And on 4S:
      2500 x 14.8 x 51.8mm = 114.996 km/h (~71.46mph)
      I recall you saying you had a 42x55 sized prop, from my understanding, 42mm in diameter and 55mm per revolution for pitch (1.25p)
      You'd probably get a fair bit of bit with that prop, was it a 2 blade or 3 blade variety?
      Comparing mine against yours, if you have a two bladed prop, you should be having a theoretical speed of 98.901 km/h or 60.95mph (with 2700kv motor on 3S)
      Hmmm, I do have a smaller prop at home that would net me a higher pitch, with 58mm per revolution, but I doubt that pitch (1.7) is going to be efficient...
      Have you tested your top speed with GPS or other?
      • masonis1
        • 1177
        #1383
        I dint have a GPS to test and frankly, I'm scared to get to top speed yet
          With pitch and multiple blades comes more amp draw.2 blade prop pulling 80 amps,the same 3 blade prop will pull 120.
          • masonis1
            • 1177
            #1385
            What really is the point of a 3 blade
              More bite on take off or out of the corners. The 1:1's use 5blades because they are hopping in and out of water.
              • masonis1
                • 1177
                #1387
                If I had a 3 blade I'd have more torque twist and steer then I already have...
                • seehuusen
                  • Apr 2012
                  • 101
                  #1388
                  thanks for the amp draw info srislash, that's really good info! :)
                  It is my understanding, with more blades comes less slippage, offering more bite/torque as well as better high-end speed
                  The ideal prop has one blade... obviously these are fairly hard to balance LOL
                  Your torque twist could probably be eliminated by a longer rudder?
                    A three blade is usually slower than a two.There are frictional forces at work.Did you know that a drag boats prop is hot at the end of a run.
                    • seehuusen
                      • Apr 2012
                      • 101
                      #1390
                      Really!!!! I did not know that, LOL that's crazy...
                      • masonis1
                        • 1177
                        #1391
                        That's cool info
                        • masonis1
                          • 1177
                          #1392
                          Seasons coming around, can't wait to see my little boat but idk about the miss geico, maybe sell???
                          • izcain
                            • Mar 2012
                            • 274
                            #1393
                            Hey Mason been awhile since I was on here since I got busy with some things. Looks like you really revamped the ol girl. Looked really nice on the runs minus the dog coming loose.
                            CF Fightercat Daytona, 21 year old Hitec Sea Nymph, Genesis and many more to come im sure.
                            • masonis1
                              • 1177
                              #1394
                              Yup, kinda depressing but she isn't fixed yet!
                              • masonis1
                                • 1177
                                #1395
                                Ran it not too long ago- I had an extra brushless from my short course truck and threw it in- it's a 3600kv lrp x20 10.5t motor. On 2s it's perfect- perfect speed and it handles it and the motor never got warm after 15 minutes of going around the pond. On 3s it's stupid fast and I pulled it out before I could do any damage! On 2s it's just a tad slower than the 2700 on 3s and I couldn't be happier with it now. The miss Gieco is for sale now and I'm Hoping to sell it and get a 1/10 or 1/8 race buggy so I have something just for racing and my other trucks for bashing.
                                I'm happy with this little boat! A blast and it handles like a dream.
