First build... Cheap boat, lots of power
  • masonis1
    If you cant control it 👍👍
    • 1177
    #1321
    here is the video, http://www.youtube.com/watch?v=g3uG3...vHSiz3oXkpbmAQ sorry for the language! a little upset
    no radio box hah i like the mess but shawn im unsure what coupler it is. i think since i soaked my flex in oil it just spun
    When speed isnt the option, change your ways
    • seehuusen
      • Apr 2012
      • 101
      #1322
      cool dude :)
        Got another place to run Mason? That pond is gonna be too small.Mind you,I hate going clear across town just to have a coupler spin and I can't get it tight enough.
        • masonis1
          • 1177
          #1324
          i have a park that has some big ponds but most the time they are filled with paddle boaters! i like testing here. plus i was low on gas so i wasnt driving far :)
          • masonis1
            • 1177
            #1325
            Found the real problem!!
            The drive dog on the flex came loose and was just spinning around the flex, looks like just a set screw!
            • dana
              • Mar 2010
              • 3660
              #1326
              Not to sound like a pansy or anything, but touching the prop while batteries are plugged in is a bad idea if that's what you were doing there. I made that mistake once and only once. Trust me when I tell you it made a mess of my thumb and I'm great full I didn't loose it. There was much blood and pain tho....
              • masonis1
                • 1177
                #1327
                Thanks hah
                  You should put a flat spot on the shaft where the set screw sits.
                  And don't play with the prop while you are plugged in.
                  • masonis1
                    • 1177
                    #1329
                    I'll take tht advice, hah how does anything even happen?! But I'll try finding a Allan wrench that will fit that screw
                    • masonis1
                      • 1177
                      #1330
                      So on the drive dog, should I remove it and then file a small flat spot or what
                        I always file a flat spot on them Mason.Just make a sharp edge at the front of the flat.This way the dog won't keep sliding up the shaft when tightening the prop.The set screw will lock against that sharp edge. Get it.
                        • masonis1
                          • 1177
                          #1332
                          I sure do
                          • seehuusen
                            • Apr 2012
                            • 101
                            #1333
                            Hey mate,
                            I was wondering, do you know how many watt your motor puts out?
                            Mine only does 1000 watt, but I've found a 1700 watt motor (leopard brand @3660 size)
                            ESC and Prop arrived today too :) Should be fun!!
                            Cheers
                            Martin
                            • masonis1
                              • 1177
                              #1334
                              Well I'm not really sure, maybe Shawn can help you out. I'm running 2700kv on 180a on 3s with a prop pitch of about 1.33
                              • masonis1
                                • 1177
                                #1335
                                Accordingly, I can pull up to 1998 watts in my set up. That is of the motor pulls 180a on a 3s... Sounds unlikely to me.
