ABC Super Hawaii
  • Make-a-Wake
    FE Rules!
    • 6057
    ABC Super Hawaii
    Always loved the look, just got it today and it is pristine, been on his shelf for years in the basement out of the sunlight. Came in the original box with a $239.95 pricetag on it. Not sure i want to rip everything out and make it a single motor stinger setup..............most likely wont. It has the steerable outdrive with a u-joint. If i use the geared twin motor stock setup, it will still retain the look (and value) of a classic boat. If i want to speed her up a bit i can simply use a couple of 3650 brushless motors in the 3000kv range and swing a big prop..........48-52mm.........that way I can keep the revs down.
  • Chrisg81983
    • Jul 2011
    • 1585
    Wow I thought I was the only person still with one someone gave me it years ago I built it for my nephew and daughter looks like its in great condition
    Chris
    • Make-a-Wake
      FE Rules!
      • 6057
      Upon further inspection, its never even been in the water.............i had to finish applying the decals tonight.
        I built one of those years ago for someone.It was a big FE for the time.Real light on the water.
          • 7512
          I had one a few years ago with dual SV electronics in it.....fast in a straight line but didn't corner well.
            Yeah,just kind of swished side to side as I recall.
            • Make-a-Wake
              FE Rules!
              • 6057
              Sure does have trouble turning from what i've seen in vids. I plan on adding turn fins and maybe even some extra weight in the keel.
              What was your setup Doby..........ESC..............voltage............ prop?
              • properchopper
                rcgoatbuild@snotmail.com
                • 7708
                Another beauty ! I remember years ago when I followed Offshore Powerboat racing this boat was on the circuit. Good find (Who needs a go-cart anyway?).
                Seem to remember from a while back that attempts to upgrade performance resulted in handling ills. Best bet could be a mild enhancement and enjoy the scale appearance. I've found from my Twinstorm days that steerable outdrives don't translate well to models. I do have a mod for the u-joint that could help-especially if it has the "ball and cup" joint .
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  Thanks Tony, whats your "mod", it has the stock ball and cup outdrive.
                  I'm thinking of possibly:
                  -Using the stock "2 motor tranny" with 3000kv 3650's on 3s thru the stock outdrive and a large prop
                  -Using the stock tranny with the twin 3000kv brushless and a stinger/rudder
                  -Or going to full shaft/flex/stinger/rudder with a 3674/4074 direct drive.
                  If i do the latter i'll botch up the stock setup in a "never seen water" speciman and may regret it
                  Pics of her after I applied the rest of the decals.
                  • properchopper
                    • 7708
                    The "ball and cup" is noisy, sucks power when angled, and wears out quickly. This is the Graupner all metal goodie which is the ticket. Input side is 3/16" so if your shaft is 4mm like on the Twinnie just sleeve with tubing. Must have the swivel joint perfectly aligned with the outdrive pivot to work correctly and will work great. I seem to remember using the Villian prop shaft for some reason (it's been some time ago.) Hobby Lobby had the Graupner joint; I may have one but I'll search if you can't source one. Leaving for Arizona WWVIII in 24 hours & I'm freakin' out (racing SEVEN classes )
                    http://www.funrcboats.com/ProductInf...uctid=TRA1529X
                    • intenserapture
                      • Jan 2012
                      • 12
                      Ive got the Gancia de Gancia nitro version of this without the steps in the hull, it will go brushless in due time. Also have the ABC nitro falcon, this will also go brushless :) Cracking boats for fun.
                        I think lots of mah would help for the weight.Should keep it planted.
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          How about a couple of these in series to hold her down a bit?
                          http://www.hobbyking.com/hobbyking/s...arehouse_.html
                            Those are good biggies.Broad and flat eh.
                            • Boaterguy
                              • 1779
                              6S on 3000kv motors?
