MHZ Mystic M 1140mm build
  • drwayne
    • 3012
    #316
    When it was in the Geico with the 1515,I guess I hit a stick and the prop must've bit because it did show a spike of 450 amps.Kept going though.
    Ouch !
    1515 is working hard for 220A.. 450+ is holybrowntime ! hehehe
    • drwayne
      • 3012
      #317
      Hi Kent.
      Fellow in Qld just confirmed hull type.
      The newest in my cathouse will soon be a Mystic C5000 114. !
      He claims 2x1527/1.5D(1550) on 6s to x447/3=~150kms
      Your 1717(1580) on 6S should hit around that mark.
      B)
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        #318
        Hi Kent.
        B)
        I knew I would get you hooked LOL, just can't resist
        • drwayne
          • 3012
          #319
          Roll your 1st cat over and measure strut cavity plz..
          Id rather use existing h/w from one the previous dozens, than source more for this toy.... !
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            #320
            You have to be more percise where you want measurement from, as there are cavities all around. If we call the measurement ABC from left to right C=120mm but where to measure AB?
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1876
              #321
              A66mm B37mm B is from the bottom point of tunnel sharpest point to where strut mounts
              • drwayne
                • 3012
                #322
                A66mm B37mm B is from the bottom point of tunnel sharpest point to top of where strut mounts
                AB is face where stinger mounts
                I think you've sorted it.
                Thx
                W
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  #323
                  So twins with twins on the lake soon hey? Sounds good to me.
                  • drwayne
                    • 3012
                    #324
                    Twins WOT on that lake will sound/look awesome....
                    I'll slow down so we run parallel.
                    will have 1816/3 ready weeks before the cat.. will test them on your toy and see what happens !
                      Ouch !
                      I've only logged spikes of 180 on the 1515,that was with the M445.Thankfully that 450 spike was only that,just a mark on the prop.
                        I look forward to a vid of the twin twins.Cool!
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1876
                          #327
                          I got 1816/3 coming as well as 4518/3 in steel LOL yeah make sure you slow down plenty get ready for big lake and fix up rescue boat
                          • drwayne
                            • 3012
                            #328
                            rescue's at the ready, M8 !
                            It's no race boat.. but good fun @ approx 35km wot !!
                            About to grab a cheapazz 2.4 TxRx for this beasty.. 14.99 from HC !!!!!!
                            • drwayne
                              • 3012
                              #329
                              Kent, whAt distance from shaft centerline to hull, or whats the largest diam prop it takes ? W
                                Oooh,did you catch Brushless55's ad.He's got 3 1717's.I only need one more NIB.I am very tempted.
