MHZ Mystic M 1140mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    #361
    Yep got that, and have just balanced, sharpened my 448 Stainless steel and polished. also my L&R 1816/3 are nicely sharpened and balanced. It takes me about an hour, and a couple of sore fingers later all done
      I hear you there Bro.Did 4 props the other night.Still got to polish them.Maybe today.
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        #363
        Hello,
        Got the lehners today, they sure look good. 6 wire output LK 8mm shaft. This should be interesting. Will use the 1717's for a bit but when good and ready the Lehners will go in. Planing to run in star mode (2250/8.5) on 8s 38600 RPM with the 4518/3 props should see speeds of ??? Well fast around 100mph if all goes well. Will post a pic later, they look really nice!
        • drwayne
          • 3012
          #364
          I think those 1717 are more than enough
          I'll swap the lehners for a pair of sharpened+balanced 1816/3.
          deal ?
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            #365
            deal ?
            DEAL!, you know the feeling...Once on your mind You have to have....LOL
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1876
              #366
              Here are some Pictures anyway......
              • drwayne
                • 3012
                #367
                [ATTACH=CONFIG]73221[/ATTACH][ATTACH=CONFIG]73222[/ATTACH]
                Yes, they'll do.
                Can you wait for the prop swap until the weekend.. or do you absolutely positively just hafta have them Tuesday ?
                hahahha
                mice buy. by the way
                W
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  #368
                  LOL can hardly wait....I received the 1816/3 got them sharp but really hanging out to try the 4518/3 that should get some speed. Also getting 4518/2 both should be good fun. Come on Prop Shop.
                  • drwayne
                    • 3012
                    #369
                    1816/3 are 45.72 x 1.6 3blades
                    just a diff blade shape to the 4518/3
                    try the 1816/3 first.. less load = less chance for a brownout
                    W
                      here are some pictures anyway......
                      PURDY
                        I have been told "end of the week" for the 2 blades
                        • drwayne
                          • 3012
                          #372
                          All fun aside Kent, Im gunna bail on the motors for props deal
                          I need a pair motors gr8 for 6 or 12S.
                          eg 12S to both, or 6S each.
                          Au Association race rules very specific.
                          Rcvd JeffWholt 3/16LR shafts today.. V nice.
                          Although.. ATM my build desk has an Aeromarine Sport40Hydro waiting for Tiny's 1717....... so Kent can rule the waves for a while with his 114 !
                          besides.. my Cat is yet to arrive !
                          W
                            Hey fellas,I tried the ABC H1818 on the DF yesterday.Sure does cavitate out of the hole.Hopefully twins will have the necessary bite.It was good once it got going though.
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1876
                              #374
                              Hmm, would they be close to the PS 4518s' then? Or would you get more "bite" from the 4518's?
                              The 4518/3 I have seen a lot of footage with, they look good but not sure about the 2 blade version. A lot of people in the German forums use the 4518/3 on their cats. Some serious speed as well.
                                It goes well once it is up and stays that way.The ABC's are 45mm and 1.8 pitch as well. Mind you,I am running 6s2p 4400mah in the DF.There is some weight.Twin screws should have the additional bite to get it up quick.The Shocker is just a tad under 10 lbs.Haven't weighed the DF.
