MHZ Mystic M 1140mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    #271
    Imagine the howl of twins on this lake !!
    It's alright mate, I'll give you a head start
    Kent is camera shy "dont show me on the video" and coincidentally FYI iPhone video is garbage.. there's not much worth watching between the edits where I removed the man
    I'm far from shy! And don't need a head start either. I'll lay low about the RRP sorry top speed you did this afternoon.... haha
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1876
      #272
      You'll probably like the extra pitch Kent.That is my next choice.Hopefully next weekend with Andy from AC Boats.BTW That lake looks awesome.Is that the new house over there?
      Hehe not my house, but I live just around the corner. I have just ordered some 1816/3 from Steve. Should get some ok speed if all goes well.
      • DINO7
        • Jan 2009
        • 165
        #273
        i just have in my hands a pair of octuras 450/3 r+l reduced to 46mm.those will be my next props testing, first with 5S and later with 6S.i will inform you about speed and ampers data by my eagle tree.i have on way to Athens a pair of propshop 4518/3 l+r for hardcore runnings.....hehehe...!!!!
        H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
        MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
        BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1876
          #274
          Sounds good dino, keep us informed are you running Leo's or Lehners at the moment?
          • DINO7
            • Jan 2009
            • 165
            #275
            hi nata.leos are in.... my mystic sit on the shelf 3 months now.i was tuning, playing with my intruder twin cat....but now is mystic time.when we have better weather in Athens-its raining now with 3 celcius-i will do some test with all props and i will post here....
            lehners are going in a new 1 meter cat that im ordering tomorow....hehehe more drug-building twin cats for me....
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1876
              #276
              Dino, any reason why you pulled the lehners out of the mystic? Are you getting better performance with the Leo's?
              • drwayne
                • 3012
                #277
                talking lehners.. what size/Kv are yours ?
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  #278
                  Hehe mine? 2280/11 so around 680kv ish loaded. Would be good on 12s with big prop
                  • DINO7
                    • Jan 2009
                    • 165
                    #279
                    i have 1950/5 2500kv.they run hot in my mystic so updated to bigger leopards..lmt motors are the best for saw ,they need full open gas for not being hot.i wanted something bigger motors for every day runnings..
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1876
                      #280
                      Could it be with the your Lehners or any other motor, that you are spinning bigger props (for the motors) but once the boat is on a plane and the props are half way out of the water, the resistance eases?? and motors spins more efficient? pulling less amps. I could not imagine that a motor was just designed to run flat out. The load is what pulls current, true? just because a motor is rated 5000w or 200A dont mean it will pull it. but even if its rated 5000w it can pull 8000w just not for long.
                      • ManuelW
                        • Oct 2010
                        • 786
                        #281
                        Hi Nata,
                        I thought it is better to continue in this thread. So as for your setup with 1717's with 1580kv on 6S I think flat out it should reach ~105km/h with X447's. As you also mentioned a runtime of 11min (may be a bit too optimistic) power consumption is really low and therefore enough potential left for using bigger props. The X450/3 should definitely work but I think they won't be enough for 130km/h - just give them a try.
                        Therefore I'd try props with higher pitch than the Octuras like the ABC 1816/3 you already seem to have. They might be a bit tricky for finding the right trimming, a quite good option are the PropShop 4518/3 (same as Dino mentioned).
                        Best regards,
                        Manuel
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1876
                          #282
                          The max speed with the 447 was 96.7 woul like to get say 130 would I get that with any props or do I need to jump to 8s? Where can I Get the propshop props? And why woud it be tricky with the 1816's?
                          • cyprus31
                            • 169
                            #283
                            Hi Kent
                            The Prop shop UK address is http://www.prop-shop.co.uk/
                            With alum 445 props from your friend Joe I got max speed 108.50 klm on 6s
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1876
                              #284
                              Hmm but you got 2200kv motor right? So you are spinning the props much faster. It would be like me running on 7s have you ordered the propshop? Would love to see what they do.
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1876
                                #285
                                Just ordered the 4518/3 SS L & R not cheap! But should look good polished hehe. Starting to have a collection of props LOL this better be good
                                Thanks Nick 4 the tip
