MHZ Mystic M 1140mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    #121
    ....and now there mine to play with
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1876
      #122
      Hello,
      Spend all day stripping hardware and wet sanding. She should be good to go in on Monday for her new color, hehe.amazingly I didn't need any filler just came up smooth by sanding. Well at least now I get some time to buff up the parts, and get it all ready for the Lehners. I think I will still use the Leopards for a bit just to see what I can get out of her. Also want to get the lehners looked at or serviced, being second hand. I'm also turning me stand into a rescue boat so combo stand/rescue, only for the fact that it's too hard to take a second boat. This way I know I always have a rescue boat with me. Will post a picture a bit later
        Originally posted by nata2run View Post
        Hello,
        OK,I can't wait to see this creation.
        • brian j
          • Feb 2012
          • 89
          #124
          If I remember correctly you offered me $300 I replied with $415. After doing that I said to myself that would be stupid to sell them so cheap. So I read listed them on eBay and wasn't going to let them go for anything under $500. Now of to Australia. They came out my Iceberg MHZ and going into another MHZ.
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            #125
            GUYS!
            My new motor stand in progress, just going to attach some pool nodles on the botton rods, and she should be floating. And ofcause a servo. Guys this is early stages so be gentle :)
            this way I asways have a rescue boat with me. And yes! the rescue boat stand will have a maiden soon :)
            • millzee
              Ozzie Bloke
              • Nov 2010
              • 1097
              #126
              I'm very interested to see the finished stand/boat, good luck, great idea!
              "Gimmy Toyz for FUN"
              • cyprus31
                • Jun 2011
                • 169
                #127
                Hi nata2run
                my name is Nicholas and I am from Cyprus. I am really impressed of your work here. The esc mount and also the servo mount are really perfect. Becasue I am also waiting for my Mystic 114 to be delivered please let me know if you could do the same set for me and to mail them to Cyprus. Is also the servo arm made by you? Would love to have also one of those. Are you using a low profile servo or standard? I have found the red bolts and nuts under the web address http://www.spotonrc.com.
                Thanks for your reply
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  #128
                  Hi Nicholas,
                  I have sent you a pm with some details. One thing I forgot, the servo arm I didn't make, and yes I'm using a low profile servo. I'm using the spektrum but would have used the savox if it was easy to get here.
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1876
                    #129
                    Hello everyone,
                    With a bit of luck I will get the hull back tomorrow from the painters. Don’t expect the world, it will be simple!
                    In the meantime I thought I would bring up some of the comments I hear, just to help you guys that might be building as well.
                    Here is goes!
                    Should really get the water pickup closer to the tunnel about 7mm, and about 18mm from the end. (Its possible I measured, but already cut the squares for the pickups.) you don’t have to use pickups either, a simple brass or aluminium tube will do (3mm bore or so)
                    Also bring the steering wires closer together on the servo arm, as you may have too much steering with little movement and loose torque of the servo. The ratio should be 1:1 if possible (so if the wires are 30mm apart on the rudder, they should be 30mm apart on the servo.)
                    All are very important points that should be addressed.
                    • silver
                      • 84
                      #130
                      Thanks, good info hope to fined some time to finish my 114 if I see how you dit everything so smood and fast.
                      hope I get everything don when spring start here in Belgium.
                      Good luck building your painted 114 and I waiting for more pics of your Nice Boat
                      regards Jim
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        #131
                        regards Jim
                        Thank you Silver,
                        Do we get you see your build?? I would love to see some more MHZ builds on here.
                        • brian j
                          • Feb 2012
                          • 89
                          #132
                          2280???
                          Those motors should be arriving soon. Please let me know when they do .
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1876
                            #133
                            Sure will you'll be the first to know!
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1876
                              #134
                              Ok,
                              Back with a few upgrades.
                              Got the hull painted and just putting things back hoping for another succesfull maiden
                              MHZ Mystic - Painted hull1.jpgMHZ Mystic - Painted hull inside1.jpgMHZ Mystic - Painted hull inside.jpgMHZ Mystic - Painted hull2.jpg
                              • battlefury
                                • 301
                                #135
                                The interior color combo really stands out even the floatation are colored to match. good job
                                http://www.youtube.com/user/f4agusta09?feature=mhee
