MHZ Mystic M 1140mm build
  • arrowskartax9
    • 130
    #46
    Gidday, Nice work with the build.
    I have a Mystic 44 Carbon Kevlar cat done up as Aquamania running twin Castle 1717 motors, twin seaking 180amp esc, Hyperion Lipos 6s and spinning Octura X447 3 Blade counter rotating props sharpened and balanced by Andy Brown.
    Have fun with your boat they are awesome.
    Chris.
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1837
      #47
      Hi Chris,
      thanks for the comment.. what sort of speed are you getting?
      • DINO7
        • Jan 2009
        • 162
        #48
        hi nata2run..with octuras 445 2blade and 5S about 120km..
        H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
        MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
        BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1837
          #49
          Sweet Dino, hope to push it abit harder with 447/2 and 450/3 props.
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1837
            #50
            Hmm capbank didnt work out as planed, too big a firework connecting the 6s. will take apart and work on connecting caps after powering the ESC's... come on props!! weather is just right
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1837
              #51
              I'm planing to do some paint work in the next couple of days, what filler should I use on the join that runs through the hull?? Any ideas out there?
              Thanks
                • 7651
                #52
                I use automotive glazing putty.Should be able to get a tube of it.
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  #53
                  Thanks! Will look into that one.
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1837
                    #54
                    Ok, I know I said she done but tonight I got the last parts done before testing and sorted out the waterlines. Got everything greased up, and hooked up some power turning the 450/3 props as well WOW that is loud!!! plus blowing some air!! on 4s 2p 5000mah plan is to use 6s 2p Hope for good weather on the weekend and will post a vid!! will GPS for sure.
                    MHZ Mystic 1140 - Final stage inside 2.jpgMHZ Mystic 1140 - Final stage inside 3.jpgMHZ Mystic 1140 - Final stage inside.jpg
                    • bruiser77
                      • 241
                      #55
                      Finally!!!! Lol! Looks really good! Like those red hose clamps, definitely get video for us. Any idea on the paint scheme? Good luck with the first run! Bruiser
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1837
                        #56
                        Well thanks Bruiser LOL not doing too bad yourself (when not filing, sanding and so on) anyway the plan is to get her silver metallic first. I'm working on this "miss machine" scheme but we'll see, for now I worry about not having to get her up from the bottom of the lake when I do the run LOL...
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1837
                          #57
                          Ok Guys,
                          I know this is not what you want to see, but you can listen to the twins spinning :) still plan to get her in the lake on the weekend.
                          • CHUD
                            • 497
                            #58
                            NICE JOB
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #59
                              Thanks Chud!
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1837
                                #60
                                Damn! Got her in the tub and some water sneaking in. Amazing what a little screw hole can do. Also used long guide tubes from the rudder pull wires almost all the way up to the servo and greased the wires inside, as the wires are submerged when not moving. I can just smell all the problems. But batts are charged ready for maiden.
