MHZ Mystic M 1140mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    How I mounted the CF Mounts was easy once I found the right spacers and cut out the CF supports
    MHZ Mystic spacers and carbon hold down.jpgMHZ Mystic installing the mounts.jpg
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1876
      Here are some pictures with the servo installed
      MHZ Mystic C5000 1140 inside Servo & wire 2.jpgMHZ Mystic C5000 1140 inside Servo & wire.jpgMHZ Mystic C5000 1140 inside0.jpg
        [ATTACH=CONFIG]66892[/ATTACH][ATTACH=CONFIG]66893[/ATTACH]
        Hey I need some of those redflared washers in the background.Have a good source for such items.
        BTW the mounts look awesome.Can you do some custom work?
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1876
          Thanks, I'm glad you like :) I got the washers in Australia from rcworld they are very cheap. Brand is called "spot on rc" you can get gold, blue, black, yellow, green and red ... I can do custom work if you need some. easy enough to ship around the world :) PM me and let me know what you need.
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            I'm working on some pictures of the rudder and the pull pull wires should have them soon
            • bruiser77
              • 257
              Very nice build! Carbon looks awesome! Where did you find the brass mounting post? I'm doing a build similar build to yours and went with red washers as well. Looks good.
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1876
                Thanks bruiser, I got the tubes from a fastner I think it was Australian fastners but any place that deal with screws for the carpentry industry should have something similar. They are around 12mm or half inch. Would be nice to see your build
                • bruiser77
                  • 257
                  It's here on OSE on the build forum under FC super daytona twin. Sorry don't know how To share link.
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1876
                    Hehe found it nice one!! Will follow for sure
                    • silver
                      • 84
                      hello, looks all verygood.
                      i've got also a MHZ 114 just delivered at home in Belgium
                      now i can start building i've got two engines leopard 4082, rudder and drives the rest i have still to by.
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        Hello silver, good choice there. Hope you know your in for a fast boat :) It's good to see someone with a close setup look forward to the prop talk as well got the boat almost ready but no props yet
                        • silver
                          • 84
                          yep, it will be a big prop talk. For me its all new i was bizzy with IOM sailboats for years but want to have somthing faster.
                          • Anbjorn
                            • Apr 2009
                            • 255
                            Well done!
                            I enjoy your work.
                            Anbjørn
                            • DINO7
                              • Jan 2009
                              • 165
                              nice work...you will love your Mystic..
                              first thing try it with props outwards ...hull turns better.
                              mine has Leopards 40/82 2200kv with swordfish240HV ..
                              H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
                              MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
                              BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1876
                                Thanks guys for the nice coments and advice. I'm still working on posting the rudder setup ( have to make a dummy to be able to show some details) next will be the battery mounts, and the water cooling, water profing the ESC's "so far they are working submerged in a glass of water" LOL... and then testing speeds!! just ordered some props from OSE
