Imax's twin carbon Shocker
  • jj2003
    HIGH VOLTAGE ADDICT!
    • May 2011
    • 1501
    #91
    2 things I have been able to verify with my CF hull that it does hinder. 1) GPS signal IS blocked. Unable to pick up any SAT's when my Garmin is inside the hull. 2) It also carries electrical current so there is no chance of putting in a safety cut off outside of the hull unless it's insulated. I'm using a Fly-sky RX AND TX with a 7" antenna with not one issue thus far. My observation is, with those two scenario's, the CF hull interfere's with any radio signal. The CF spreads the signal apart too much and distance become's a factor, or it blocks it all together, based on the GPS issue.
    "If guns cause crime, all of mine are defective"
    45"Speedfreek
    , Fightercat #068 ​, MyYoutube Vids
    • jcald2000
      • 768
      #92
      You MUST have the ant. outside the carbon fiber!, if you value you boat, if not go ahead.
